Replace door seal
Changing a door gasket on a fridge is one of the most aggravating repairs in my opinion. The best advice I can give on this is make sure you take the door off, do not remove the screws all the way, just loosen then as needed, and heat the new gasket to make it pliable when you put it on the door. Hopefully you machine is one of the ones that has a magnetic gasket so you can just peel the old on off and throw the new one on without a problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: cracked leaking door seal
Part 201 on this diagram and you can look at the freezer door diagram for it. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=18149&diagram_id=782438#d782438
