Hold down the F1 key, then, while continuing to hold it down, press the power switch. the system will turn on, then prompt you to check system and press F2 (thats from memory, it maybe F1 again) to enter BIOS. With many Toshibas you can hold down any key to do this, as it simply generates a keyboard error, prompting the same message. Hope this info helps.
The DVA-5205 has to have an infrared remote module plugged into it to receive the signal from the remote. I have one also and it doesnt have one and it wont do anything without it. I'd like to know where to get one if you find out. Alpine seems to stop making everything for older models once they come out with new ones.
I may be able to help.If you can tell me what codes the tractor has stored that would be a good place to start.You can get the codes by putting a fuse in the "cal" position of the front bottom half of the fuse box,then use the signal light switch right turn signal to get to each controller.When you get to the controller you want(bcu,hcu,rcu,bif) pull back on the signal light switch(flash to pass) and the signal right one more time.Next you need to momentarily turn on then off the hazard lights.Now record the codes in each of the controllers and send them to me and we will go from there.Let me know if you can,t get this to work.
sounds like you are all too familiar with battery terminal isues but I think you're on the right track sounds like a cooked solenoid left side of the tractor if memory serves the JD part is good quality but I,ve replaced a few with a standard automotive one and had no problems a little cheaper too ...Ok alot cheaper Good Luck
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
