Hi, You don't change it. Your t.v. will play at 1080p if it is a native 1080p t.v. and it is receiving a 1080p signal. If it is receiving a 720p signal. Then it will play at 720p. If your t.v. is native 720p and receives a 1080 signal. It will scale down the signal to 720p.
You have to adjust the settings on whatever is connected to your television. If you have a bluray player connected to your television with an hdmi cable you should be able to receive 1080p but you have to set the bluray player to 1080i. The tv picks up the signal automatically. From your cable box or satellite tv box you cannot get any more than 1080i from television programs at this time. You can get 1080p from bluray on demand. In certain circumstances you can get 1080p over component cables as well as an hdmi cable but in most cases you will only get 1080i. Once again you have to set your connected device to 1080 to get it on your tv
I hate to be the one to break this to you, but there is very little 1080p content available to be viewed on your television. Telus TV outputs only 720p or 1080i video, so you are getting the best available picture already. The exception is Blu-ray, where almost all content is played at 1080p if you use an HDMI cable.
Please make sure that your receiver can display high definition signal, such as 720P, 1080P. As you know your HDTV is high definition source, it can only be displayed on the display machine that have ability to display high definition HDTV signal. This will help.Thanks,please
keep updated. please do rate the solution positively .thank you for using fixya
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
If you are using the component connection, make sure you are connected to the one that will support 1080i. If that is not the problem, make sure that the HD receiver is outputting 1080i and not 720p. No RPCRT will support 720p and the video may be down-rezed to 480 since this is the case.
in addition many TV service providers are unable to send a true HD signal. the max is 720p or 1080i as refered to above. some sattelite companies are beginning to dabble in it but nothing full swing as of yet.
Hi - Here is a description of a few terms that might help, especially if you're in the market for a tv. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be glad to assist you further. Thanks.
High definition television is the highest form of digital television. It has a 16:9 aspect ratio, which is the same as a movie theater screen. This is possibly HD’s biggest selling point. The other is the resolution. High definition is the best available picture on a television. It comes in three different flavors: 720p, 1080i and 1080p. What do 720p, 1080i and 1080p mean?
High definition programs are encoded with a type of resolution: 720p, 1080i or 1080p. The number stands for the amount of lines embedded within the signal. The letter describes the type of scan the television uses to display the picture. The ‘i’ means interlaced and the ‘p’ means progressive. Why does the amount of lines matter?
The number of lines on a television is important because it allows for greater detail in the image. This is a similar concept to digital photos and how dpi determines print quality. The type of televisions all of us grew up watching had 480 visible lines on the screen. By doubling the amount of lines in combination with the type of scan, HD essentially doubles the quality of picture. Does it matter if the resolution is interlaced or progressive?
The type of scan is arguable considering the amount of lines for each HD format. Progressive scan is a better type of scan because it doubles the amount of times the TV displays the image per one second in comparison to interlaced. Still, the difference between 720p and 1080i is so minimal that is isn’t an issue at all. While 1080p is better than 720p and 1080i, very few programs are made in this resolution so it really isn’t a factor right now…and, it might never be.
Your tv, 32LA30Q Television can only support up to 1080i, not 1080p, that is why you cant run it at 1080p, as the hdmi inpute only allow, 1080i, 720p, 480p and 480i signals.
