Hi, I have a sudden problem with VGA output. Whenever I connect my T-60 to a projector (Epson one) it becomes immediately frozen. I have to press and hold the power button to restart it. The only workaround is to connect the projector before startup. Then it works, however when I unplugged the projector the T-60 is frozen again. I’m using Windows 7 ultimate 64-bit.
SOURCE: T30 cannot connect to projector/external monitor on windows 7.
You can connect your computer to a projector to give a presentation
on a large screen.First make sure the projector is turned on, and then
plug the display cable from the projector into a video port on your
computer.
Then press Win Key+P or run DisplaySwitch.exe and choose your preferred display.
Note:1.You can use this same procedure to connect your computer to a monitor
2.This will have no effect if you’ve only one display connected
SOURCE: I have Windows 7 Ultimate
Access "Windows Update" and do a "search for updates".
If there are any "optional updates", those updates could be the device-driver for your device.
SOURCE: I can't get my IBM
It sounds like a failed motherboard, If it was stuck in sleep mode the computer would still turn on.
try leaving the battery removed plug in the laptop and see if it turns on, if not it sounds like a bad component on the motherboard.
