A
Anonymous Posted on Jun 20, 2012
Reset 80 scheduled maintenance Lexmark E352dn
1 Related Answer
Anonymous
  • 11 Answers
  • Posted on Jun 17, 2009
SOURCE: 80 scheduled maintenance
This issue is just like changing your oil or the timing belt on your car. If you don't fix it correctly it leads to other problems. So, be warned. :+)
Here's what the Lexmark KB says:
On the Lexmark T520/522 series printers, we recommend that the maintenance kit be replaced after every 250,000 pages. If possible, an authorized service technician should replace the maintenance kit parts on these printers.
On the Lexmark T620/622 series printers, we recommend that the maintenance kit be replaced after every 300,000 pages. The maintenance kit parts for these printers are customer-installable, but some dismantling of the rear area of the printer is involved.
Note: The maintenance kit may need to be replaced more often if the customer is running heavy media (like card stock or labels) through the printer.
It is possible to clear the maintenance error message without replacing the kit. The printer will still operate, but some print quality problems may arise. However, this is not recommended as the message serves as a reminder that maintenance is due. If the printer is under warranty, the customer has to purchase the maintenance kit and have it replaced in order to keep the warranty active, although the on-site replacement itself may be covered under the warranty.
The parts that make up the maintenance kits are:
A fuser unit
A transfer roller
A charge roller
To find the part number of the maintenance kit needed for your printer, see Printers / Maintenance kits.
Clearing the maintenance message
To clear the message, you will need to go into the printer's configuration mode. Do the following:
  1. Press and hold the SELECT and the RETURN buttons as you power the printer on.
  2. Hold the buttons for six to eight seconds after turning on the power, then release them. (If you receive the maintenance message, press the Go or the Select button to continue past it.)
  3. Now, press the right Menu arrow until you see RESET MAINT CNT.
  4. Select this. You may need to press the Select button again. The printer display should briefly flash SAVED.
  5. Power the printer off and then back on in the normal way. The printer should now power up normally.
  6. If it does not and the error returns, repeat the above procedure.
Reset maintenance count
T632 reset maintenance count: Press and hold down the "select" and "return" keys while powering on the printer, hold these buttons until the display reads " 80 Scheduled Maintenance, press the "go" to continue past this message and access the configuration menu. Press the menu button until the display reads "reset Maint Cnt" on the second line of the display and press the " select" button. the top line of the display should nnow read "reset maint cnt" and the second line will read "reset" and pressthe "selcect" button. this will reset the counter to exit out of the "configuration mode" cycle the power.
Error 80 on a lexmark t642
Hello. Welcome to Fixya
Actually Error 80 is "Scheduled Maintenance Message"
You can reset the maintenance count by going to the Configuration Menu
Follow the given steps to solve it:
  • First of all Turn off your printer
  • Hold the 2 and 6 buttons while the printer is off
  • Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 seconds
  • On your Operator Panel, you should see "Configuration Menu"
  • Scroll down and look for "Reset Main Count" and select it.
  • Exit Configuration Menu and turn the printer off then back on
I hope it will be solved, If it doesn't work then
You are required to purchase the maintenance kit and have it replaced even if the printer is still under warranty. Some maintenance kits can be installed without the assistance of a technician. However, some warranties cover on-site installation of the maintenance kit by a technician after you have purchased the kit.
In this case you must be contact to LEXMARK service provider, To get support by LEXMARK on phone, then call at 1-800-539-6275
I hope this solution will surely helpful for u
If its is helpful then please don't forget to click on Four thumbs which are given below this solution
THANKS & Keep Using Fixya
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
1helpful
How do I install a Lexmark E352DN Photoconductor
Here's an article on How to Change the Photoconductor Unit/Kit on a Lexmark E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/aykTXL. This should give you an idea on how to install the photoconductor unit in the Lexmark E352dn printer.
NOTE: If you are replacing your old photoconductor unit with a new one, after installing it you will need to reset the photoconductor counter as well.
5helpful
Reset fotoconductor lexmark e352dn
NOTE: Resetting the photoconductor counter/page counter should only be done whenever you replace the photoconductor unit.
Here's an article in the Lexmark website on how to reset the photoconductor page count. Just click on this link: http://bit.ly/9WAvUK. Hope this helps.
2answers
How reset the printer maintenance counter for the lexmark t642
Here's an article in the Lexmark website on 80 Scheduled Maintenance" Message Appearing on a Lexmark T640, T642, T644, or an X64xe Series Printer. Included in this article are instructions on Resetting the maintenance counter to zero. Just click on this link: http://bit.ly/9pzU7R. Read thoroughly and follow the instructions carefully. Scroll down for the instructions on resetting the maintenance counter.
NOTE: RESETTING THE MAINTENANCE COUNTER SHOULD ONLY BE DONE ONLY AFTER REPLACING A NEW MAINTENANCE KIT.
3helpful
2answers
A fuser unit
A transfer roller
A charge roller
8helpful
2answers
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
28helpful
2answers
Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
