I ran out of diesel fuel in my 2004 gmc sierra 2500 duramax diesel. I put diesel fuel in it and now the vehicle won't start.
This is not unusual on a diesel. What happens is there is air in the system. If this vehicle has an electric fuel pump loosen line where fuel enters injection pump then turn ignition key to the on position and watch for fuel to appear and then quickly tighten line before turning off key. Then try to start. If does not have electric fuel pump will need a second person. One will loosen line and watch while other cranks vehicle until you get fuel and tighten line before the other person releases ignition switch unless vehicle starts first. If that doesn't do the job do this where line hooks onto each injector. Probably will not have to do this to all injectors but could run rough until all the air gets out of everything. I have farmed with diesel tractor for 25 years and dad I drove the gm vehicles with the 5.7. You normally don't start a diesel without bleeding the air out of the lines although some will self bleed most won't. Hope this does the trick.
SOURCE: I need to replace the fuel filter on my 2003 GMC
ITS A SPIN ON FILTER, YOU NEED TO DISCONNECT THE WATER SENSOR ON THE BOTTOM OF THE FILTER, THEN USING A STRAP FILTER WRENCH LOOSEN THE FILTER AND SPIN IT OFF.
CHECK THE FILTER HOUSING TO BE SURE THE INNER FILTER SEAL ISN'T ON THE HOUSING AND CAME OFF WITH THE FILTER.
REMOVE THE WATER LEVEL SENSOR AND DISCARD THE SEAL.
INSTALL THE WATER LEVEL SENSOR ON THE NEW FILTER. USING A LITTLE GREASE ON THE INNER FILTER SEAL AND ON THE OUTER O-RING TO HOLD IT IN PLACE, SPIN ON THE NEW FILTER.
OPEN THE VENT ON THE UPPER SIDE OF THE FILTER HOUSING. PUSH DOWN ON THE HAND PUMP QUICKLY UNTIL THE FUEL IS COMING OUT OF THE VENT. CLOSE THE VENT AND PUMP THE FILTER PUMP UNTIL IT FEELS SOLID. AT THIS POINT START THE ENGINE. IF IT STALLS PUMP IT UP AGAIN AND RESTART THE ENGINE. IF YOU HAVE AN ASSISTANT THEY CAN PUMP THE FILTER PUMP WHILE THE ENGINE IS RUNNING AND QUIT WHEN YOU FEEL THE ENGINE IS NOT GOING TO STALL. ABOUT 10 TO 15 SECONDS USUALLY WORKS.
CHECK FOR LEAKS.
BEFORE STARTING THE ENGINE USE BRAKE WASH TO REMOVE THE FUEL SPILLED DURING THE FILTER REPLACEMENT. ALLOW IT TO DRY BEFORE STARTING THE ENGINE.
RATE ME PLEASE.
SOURCE: Excessive black exhaust on 2003 GMC Sierra Duramax Diesel.
This is what i would try (cheapest first) redexe/wyyns
injector cleaner,double dose,then i have put 1gal gas in 10gal diesel to increase burn temp (you may encounter a hot start problem temporarilly)then if still smoking, get a compresion check on the engine(this will tell you volumes)
by the way the NATO tanks put in 1/3 gas in diesel to stop it freezing in arctic conditions.any more than 1/3 can result in problems.
SOURCE: 2003 gmc sierra duramax 2500
Problem with Diesel Fuel System. Gmc 2002 duramax 2500 HD 4x4 will start
SOURCE: 1999 gmc sierra 2500 6 liter ran out of gas now won't start
If you are at or near the 100,000 mile mark then your fuel pump may have failed. If you remove the fuel filler cap and listen carefully at the filler neck while someone turns the ignition key to "run" [don't actually crank the engine] you should be able to hear the fuel pump buzz for about a second and a half as the key is turned On. If you don't hear the pump buzz then odds are your pump is dead. Your pump may have actually failed making it appear as though you ran out of fuel. Not to uncommon. Hope this helps and good luck!
SOURCE: my security light stays on & won't let my 99 gmc 6.5 diesel sierra start any solutions
Yes, the system is called Passlock, and malfunctions regularly. Go to this link for an explanation of how it works, plus some tricks and tips on how to reset it, or bypass it.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
