My epson 7600 was working just fine and all of the sudden no ink is coming out onto the paper. It runs like it's printing but doesn't print anything. Any ideas?
SOURCE: Epson R1800 refuses fine art papers
Hi Fruitless, Last night I was tearing my hair out trying to get my R1800 to accept some Hahnemuhle Satin 310, and it was just passing through and passing through. About once in 20 trys it would finally print. I was in the middle of making up my own paper profiles for this lovely paper. Anyway, I gave up at about 1:30 am, and went to bed. Today I resumed my attack, and guess what fella, there is a solution. Pass this on to everyone. You did not say what version of Photo Shop you were using. I just got my CS3 a week ago, and if you are using it, you can open a photo for printing. Go to Printing Preferences Dialog Box, > click on Maintenance Tab, and then click on the Bottom button that is labeled as Printer & Options Information. The Printer and Options Dialog Box opens, and there at the bottom is a box that says Thick Paper right beside it. Select or check this box and enjoy yourself thereafter. I did not see this in the User's Guide, but knew there had to be an answer to this problem somewhere. No problems ever since. Best of luck.
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
SOURCE: Epson DX8450 not printing
are you using leopard os x? when you said you loaded the driver for the printer, did you use the disk that came with the printer?
SOURCE: Printer won't print
epson printers has a seprate printing head that holds the ink . when your inks are new & good .utilizes fixya repair directory to find a repairman to change the printing head for u .
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
