SOURCE: Need this part also 25000820 (atenna block assembly) for my TV.
Where are you located? USA, UK?
SOURCE: Sony FD Trinitron KD-34XBR960 34" TV
Our set turns itself off by itself. Prior to this happening, it goes to a green screen. It usually happens after the set has been on for a couple of hours. We bought the set in April, 2004 and the warrantly has now expired. The longer we keep the set on, the more it turns itself off. Is this a tuner, on/off problem or the tube? Any estimates for repair?
SOURCE: We have a SONY kd-34XBR960 I turned it off and
Turning your tv off did not cause this issue, so don't blame yourself for that. A 6 or 7 blink shutdown is because one of the two switch mode power supply control ic's have failed. the part number on them is mcz3001. They are located on the "D" baord, i don't recommend replacing this yourself because even with a tv unplugged from the wall high voltages still exist in the set.
A repairman may preform one of the two following things, he may change the whole D board or he may replace the individual components. The repair will cost around $200 if they replace the components, and if they replace the board it will cost more.
SOURCE: I have a Sony KD-34XBR960 that sound like it is
phillips has the same problem but if your tv actually turns on it could be a short or just a fuse sonys a better tv than phillips should be an easy fix call a repir guy going price for that problem is 75.00 dont pay any more than that. the economy is bad everyone needs the work be smart. make sure if you say yes to the work that the repair guy will waive the consultaion cost of usually 35 to 75 dollars, if you chose to have the work done.
I have asked the TV repairman if the XBR970 parts will work in the XBR960 and he does not know . So , ya see thats why I'm here looking for help .
