Nikon Zoom Tele 80-400mm f/4.5-5.6 D-AF VR (U.S.A.) Lens Logo
Posted on Jun 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
80-400 NIkon won't zoom on NIkon D700
Nikon 80-400 just came back from Nikon, cleaned"ready to use". I put ito n my D700 as I would any lens, set it to A, and the zoom lens will move ( manually), but it is not zooming/focusing. Am I missing something with the set up?
Bart Pulverman
Level 2:
Guru:
  • Nikon Expert 362 Answers
  • Posted on Jun 18, 2014
Bart Pulverman
Nikon Expert
Level 2:
Guru:
Answers
362
Questions
0
Helped
83664
Points
625
Not if your other lenses work ok. I would contact the Nikon Repair Depot that cleaned it.
5 Related Answers
Anonymous
  • 667 Answers
  • Posted on Jan 19, 2008
SOURCE: Parts and service manual of Nikon ED AFNikkor 80-200mm 1:2.8 D zoom lens
Nikon Parts
841 Apollo Street, Suite 100, El Segundo CA 90245
(310) 414-8107, (310) 322-6979
Anonymous
  • Posted on Apr 25, 2008
SOURCE: Problem with the Nikkor AF-S DX 55-200 zoom lens.
I just had the same exact problem! However, in my case I was finishing up a photo shoot at work, went to switch lenses, and when I picked up my 55-200mm zoom lens, the tip of it fell off!! I was able to put it back into the end of the lens, but now I am having the same autofocus problem and sound effect. I think it is because it is off track inside the lens. But I have only had mine for 5 months! I'm preparing to send it to Nikon for warrenty repair.
Anonymous
  • 216 Answers
  • Posted on Jan 04, 2009
SOURCE: nikon dx swm 18-55 mm
This is a very common problem. It sometimes happens without cause, sometimes by tightening or removing a filter. There are a couple of keys that keep the front lens from rotating while zooming that are very thin and easily bent. They have to be removed and straightened, and the rear piece you see floating has to be reinserted. It's about a $40 job and half-an-hour by a local independent repair shop. Expect to pay Nikon twice that.
Glyn Kendall
  • 146 Answers
  • Posted on Jul 04, 2009
SOURCE: Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
Anonymous
  • 37 Answers
  • Posted on Jul 13, 2009
SOURCE: My nikon 55-200 zoom lens is stuck at full zoom
Don't force it.
Did you get dust or dirt in it?
The only solution is to bring it in for service or send it to Nikon if it is a USA model.
Nikon USA will NOT repair any gray market items.
Nikon d700 hotshoe missfire with flash nikon sb900
Probably a loose hotshoe. This is a common problem with the D700 hotshoe and SB900 combo. The weight of the SB900 eventually loosens the hotshoe, meaning the internal screws holding the hotshoe in place loosens.
2helpful
Can't download from D700 camera to computer
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer and Picasa.
2helpful
Unable to transfer pictures from nikon d700 to computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery, iPhoto, and Nikon Transfer.
1helpful
MANUAL FOR D700 NIKON
Welcome to FixYa.
Nikon D700 Non-printable User Manual http://www.nikonusa.com/pdf/manuals/noprint/D700_noprinten.pdf
Nikon D700 Printable Manual (may require serial number validation) http://www.nikonusa.com/pdf/manuals/dslr/D700_en.pdf
Thank you for using FixYa.
Have a great day!
Jas247
Is the 1988 Nikkor 28-85mm F3.5-5.6 lens a good alternative mid rang lens for Nikon D700?
Absolutely. Here's what one reviewer has to say about it:
http://www.kenrockwell.com/nikon/2885af.htm
Can I use TOKINA lens 28mm-210 lens with this Nikon body or can I use with other NIKON body D 700?
Tokina makes their lenses with a variety of mounts. A lens with Canon mount, for example, won't fit onto a Nikon. Assuming you get the lens with a Nikon mount, then yes, you can use it with a D70 and with a D700.
I can transfer images from my nikon d700 to my desktop. The Nikon software have been installed in my computer. Every time I switch the camera on, to start transfer. The computer system says installed...
Your computer is looking for a mass storage device. Go through the camera menu system and make sure "USB Connection" is set to Mass Storeage, then Windows will automatically install the drivers.
I Have nikon D700 camera i can used any old manual lens
You can download a free PDF manual from Nikon at http://support.nikontech.com/app/answers/detail/a_id/13948
If you want a printed manual, you can order one from Nikon at http://www.nikonmall.com/category/instructionmanuals
Have new Nikon D700. Have Mets flash gun. Have
Even older flash units from the same manufacturer can damage newer digital cameras. It's a matter of the trigger voltage. Older flashes can put a lot more juice through a digital camera than the camera can handle.
Since you neglected to specify the model of your Metz flash unit, I can only suggest you look it up here.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
