A while back, the red 'alarm' light lit along with 3 and 7 temeprature buttons both flashing together. This flashing was also accompanied by a rather annoying 'beep'. Looking in the manual, it recommends I contact Whirlpool and arrange a service engineer, although it does also say the temperature will remain ok. Whilst not ideal, I lived with it for a month or so, but this annoying beep, drove me up the wall. So, I decided to act on this and set about removing the beeper from the circuit board. Removal of the panel from the inside of the fridge was easy and I soon had the beeper off and silecnced forever !!!!!! Since silencing of the beeper, the fridge now seems to be very cold even though the temperature is set to 7 degrees. And the flashing error code remains. . . . Any ideas as to what I can do to fix this thing ? How can removal of a beeper cause the temperture to drop ?
Cheers
Your appliance is short of refrigerant
Same thing happen to mine. Tried the defrost method but did not work. Called out a service engineer who replaced the thermostat worked for about one year then same thing again. Still beeping so gave up with this fridge. Looking at a different fridge to replace this one.
I have had similar problems with the electronic control module. Replacing the whole module would cost about £160. I have repaired mine by bypassing the electronic controls. The fridge compressor is controlled by a 12 volt relay on the circuit board. I have wired the relay to an extenal frost thermostat (Sunvic TLX9401, £12.50 from toolstation.com) and it now works OK.
Philip Shields
APM 6528 fridge keeps alarming.
Same problem. Defrosted fridge, switched off for an hour, removed cooler box, tried everything in the book.
Trevor
Defrosted the fridge, switched off for an hour, removed the cooler box, tried everything in the book, same problem.
cheers Trev
