HP Photosmart C6200 Owner Manual Photosmart Express Menu Setup Menu
When you press the Scan button on the HP Photosmart C6200, it seems to require the HP-All-in-One Network.
Page 11 suggests that "The Scan to Computer option only appears if the HP-All-in-One Network is connected."
The Basics guide on Page 8 suggests that the All-in-One software allows the use of a network cable or a USB cable.
http://h10032.www1.hp.com/ctg/Manual/c01147544
I don't have one of these to test. It seems frustrating that the scan button doesn't automatically allow Scan to Computer option without installing HP all-in-one software, but you should be able to experiment, installing it, and if it works, you can see what works or not.
SOURCE: Scan to computer
where do I look to find the solution? Must be somewhere to click, but I can not get my eye on it.
SOURCE: When I go to "scan menu" the option "san to microsoft word" doesn't show up anymore?
I had the same problem but I now can do it ! I went to my applications and in the HP FOLDER is HP SCAN PRO ---I put that icon on my desktop on my MAC and now whenever I want to scan to my computer its just a click away. Just click scan pro and hit scan and then you can put it were ever you want on the computer.
SOURCE: My scanner won't work.
look dor the hp imaging solution on the bottom of your computer screen. Click on it and when the screen come up clip on the button that is closest to what you are trying to do.
SOURCE: Can't scan from HP Photosmart C7280 to my Mac Computer
The best way to scan documents from the scanner to your computer is to use HP Photosmart Essential. If you don`t already have it installed it can be downloaded from the HP site. Once in the program it is very simple to follow. It is basically a point and click operation.
Let me know how you make out and we can do other things if this doesn`t work for you.
Please remember to rate me.
SOURCE: HP C6280 won't let me scan to the computer. Only
ergo your problem!!
You must have scanning software installed on your PC in order for the 2 devices to communicate. It should have come bundled on the CD you got with the printer. I believe the HP software is called HPDirector.
Please find on your PC or install from your CD & that will enable you to scan to your PC.
It may already be installed. You will need to run the software to enable communications between the 2 devices.
Thanks for using FixYa - a FixYa rating is appreciated!!
i have the same exact problem. can someone help??
Same problem here! Troubleshooting guide no help at all.
