Nokia 2630 Cell Phone (Unlocked) - Black Logo
Posted on Dec 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I forgot my security password
I first apply a securitykey password and then i removed it
Then I forgot my password
When I again on the security code it asks me for a code.
how can i remove this problem
  • 3 more comments
  • sbb1974 Dec 04, 2008
    i have given security code for my nokia 2630 model phone when i swith on the phone asking security code i forgot the security code
  • Anonymous Dec 09, 2008
    i forgot my password of nokia 2630.reset it.
  • umeshkolkata Jan 06, 2009
    forgot my password and had changed the default
  • ashu124 Jan 29, 2009
    forgot security code
  • Anonymous Jan 29, 2009
    forgot puk code now my phone is blocked
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Dec 09, 2008
Anonymous
Contributor
Level 1:
Answers
27
Questions
0
Helped
26393
Points
46
You can reset your security code for nokia mobile this code is diffrent than nokia unlock codes.
below is one example for resetting security code.
*#7328748263373738# resets security code.
Default security code is 12345
keep in my diffrent nokia mobile have diffrent code so you can try this code with you mobile. here you can get nokia unlock codes for diffrent nokia model. this blog has all detailed information about nokia unlocking and master codes for nokia.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 272 Answers
  • Posted on Dec 04, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
272
Questions
Helped
127156
Points
603
If your phone is blocked. You will have to take it to your nearest network provider outlet to get it unblocked.
If your sim card is blocked. You can go to your network suppliers website, where you can obtain the puck code to unblock the sim.
2answers
HOW DO YOU UNLOCK THIS PHONE WHEN YOU FORGOT YOUR SECURITY CODE
Click on forgot password...then it will ask for gmail account and password..fill those columns..
After that you can apply for new password
Apr 15, 2016 • Cell Phones
tip
PDF encryption, set PDF password and recover PDF password
PDF encryptionGenerally, PDF files are with a password called User Password, which is used to open the file and view the document. To encrypt a PDF password does not simply mean you can’t open and view the document, but PDF files have five to seven encryption ways to protect the file for office needs. Owner password, the other password of PDF files, is another crucial PDF password, which is to protect the file from maybe being copied (to Clipboard), printed, or modified, etc. So, in speaking of PDF password, it doesn’t necessary mean the one which you use to open the file.
PDF encryption largely relies on the sophisticated algorithm that hardly to be reversed. For example, you are easy to calculate that 1000 plus 1 is 1001, however, the reverse is seemed impossible, for 1001 can be an answer of countless calculations. PDF encryption works in the similar way. In this sense, given a password, it’s easy to deduce and decipher some data; however, the reverse PDF password recovery seems impossible.
Generally speaking PDF encryption with 128 bits key value is much more secure than that of 32 bits. PDF encryption is accomplished by a key value, either 128 or 32 bits in size. When using the key, all the bytes are changed (unless they are decoded back with the same key) into meaningless codes, and the file is impossible to be opened. Only the meaningless codes are calculated back using the correct value is it possible to get the correct password and open the file. 128 bits has a lot more possible values than the one with 32 bits, so it is much more secure. If your password is forgotten and intend to recover PDF password, PDF Password Unlocker software could be faster, for it supports 128 bits encryption, either 128 bits RC4 or 128 bits AES encryption.
PDF files are composed with objects, like image Objects, graphic Objects, and text Objects, etc. The key is calculated for each PDF Object in the PDF file using local data, which is much hard to crack, as the key keeps changing.
Set and remove PDF passwordsAdd a PDF Password1. Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002.jpg in the Tasks toolbar, and choose Password Encrypt.
2. Click “Yes” to the prompt about changing the security, and if necessary, type the Permissions password that lets you change security settings. If you don’t know the password, contact the author of the PDF.
3. In the Password Security - Settings dialog box, set the security options as desired, confirm the password, click OK, and then click OK again.
4. Save the document to apply the security settings.
Note: You can also restrict editing capabilities when you certify a document, or when you apply a policy to a PDF.
Remove PDF passwords and security settingsYou can remove PDF passwords and security policies from an open PDF if you have the permissions to do so. If the PDF is secured with a security policy that resides on a server, the changes can be made only by the author of the policy or by a server administrator.
1. Do one of the following: Click the Secure button pdf-encryption-and-pdf-password-recovery_clip_image002_0000.jpg in the Tasks toolbar, and choose Remove Security.
Type your password, and click Yes to the prompt about removing the security.
In the Security tab of the Document Properties dialog box, choose No Security from the Security Method menu.
2. When prompted, specify the Permissions password, and then click OK. Recover PDF password in case you forgot it.Every coin has two sides. Even the PDF document is strongly encrypted with passwords, it is impossible to insure that it is secure. Once you forgot PDF password, the data in the encrypted PDF file are on the risk of unavailability. Unless fortunately the password knocks your memory again, you got the data lost or you have to give up the document eventually. With the ever-growing of strong encryption algorithms, decryption algorithms gradually come into existing, too. Though the cracking is far more difficulty than ever before, it is still of help to those expecting to recover PDF password and access the password protected PDF file. Take PDF Password Unlocker, a popular PDF password recovery software, for example, it has adopted the advanced decryption algorithms to crack 40-bit RC4, 128-bit RC4, 128-bit AES, and 256-bit AES encrypted passwords with 3 attack methods, Dictionary attack, Brute-force attack, and Brute-force with Mask attack
Reference: http://www.passwordunlocker.com/knowledge/pdf-encryption-and-pdf-password-recovery.html
on Apr 30, 2010 • Computers & Internet
2answers
I forgot my security code nokia 1202-2 IMEI: 356925/03/932289/4
Hello:
Type *#06# and note your IMEI number.
Go to below site
www.nokiamastercode.com/
And generate master code.
After applying master code goto phone setting-> security setting-> change security password.
Salutations
Manuel
I forgot my password code
What is your mobile and model ?
If you forgot the security code you have to reset you mobile..... Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means visit here Theunlockspot.com for the master reset code service and get the reset code........
Apr 05, 2012 • Cell Phones
Can t unlock my phone forgot my password
What is your mobile an model ?
If you forgot the security code you have to reset you mobile....... Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means visit here Wickedunlock.com for the master reset code service and get the reset code........
Mar 14, 2012 • Cell Phones
FORGOT PASSWORD TO CELL PHONE
If you forgot the security code you have to reset you mobile. Its the only way to use your mobile again. After resetting you can enter a new security code again.
If you use nokia or alcatel mobile means visit here Unlock-free.com for the master reset code service and get the reset code........
Jan 29, 2012 • Cell Phones
1helpful
I locked my sidekick lx with a privacy lock code & forgot passwor
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
1helpful
2answers
6300 securitycode
I have forgot my security code how can I get it plz help me
3helpful
2answers
Forgot d keypad password.........
hello,patel.......
reset ur security code..... this wil help u.......
pls enter *#7328748263373738# this wil resets security code....
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
