I only get a blue screen saying enter password when i open the computer. I cant use boot at all or open the case. Help me. I only need the password they are using???
After hours of searching I finally found a fix:
1. Remove the battery
2. Remove the HDD
3. Removed the RAM to make the solder points, marker 'J1' on the motherboard visible
4. I then used a paper clip and sticky tape to join these solder points
5. With the solder points joined, insert one stick of RAM and turn the machine on
6. Wait until the laptop is in a post BIOS state (past the screen where you can press F2 for setup and where the logo shows) and remove the paper clip. This has to be removed while the laptop is still on.
7. Turn off computer, press F2 to enter BIOS and you should find there is no password.
Repeat the above steps if you find this doesn't work.
Do this work?
Worked for me
This WORK and will WORK with all password related bios issues as it resets the bios to default
thanks Jack
not true
only the boot pw, is easy
boot pw
bios admin
bios user
bios HDD pw lock (impossible=
It worked for me. I was stuff for 4 days trying to insert "Factory BIOS" passwords... Then I did this...
?1. Remove the battery
?2. Remove the HDD
?3. Removed the RAM to make the solder points, marked J1 on the motherboard visible
?5. With the solder points joined, insert one stick of RAM and turn the machine on
?6. Wait until the laptop is in a post BIOS state (past the screen where you can press F2 for setup and where the logo shows) and remove the paper clip. This has to be removed while the laptop is still on.
?7. Turn off computer, press F2 to enter BIOS and you should find there is no password.
?Repeat the above steps if you find this doesn't work.
Thanks a lot! I soldered that J1 contacts together, put battery and AC adapter back I push power button several times. CMOS battery no need to disconnect for me. After that , I desolder J1 back (witout AC adapter and battery of course) and start laptop normal. And there is no BIOS password.!!!!
You need to open the case and remove the CMOS battery (Button Cell - usually CR2032).
Leave this out of the machine for 10 minutes so that the BIOS settings are lost. Turn back on and the Computer should have reverted back to Default settings. You will need to reset the Time & Date afterwards.
SOURCE: BIOS PAssword
Here is information on CMOS BIOS passwords. You have to follow instructions closely. Aside from that, there is no other way.
http://www.tech-faq.com/reset-bios-password.shtml
SOURCE: default bios password toshiba satellite a135-s2276
I have a Satellite A135-S2356 that had the same problem. I tried the solution from PCTServices above and it worked great.
"Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw."
Just short the two little solder pads and it worked great! I thought I would have to send it back to the manufacture but I am back in buisness. Thanks for the help.
Bryan
what you need to do is pull both the laptop battery as well as the cmos battery. in some instances, the battery can be pulled, but on other models, i have seen the battery as an actual physical part on the motherboard or somewhere where it is not easily accessible, in which case you need to clear the cmos by using a jumper on the motherboard, since it is a laptop, they are all different. you may need to see if you can locate a copy of the motherboards schematics and go from there.
SOURCE: Keys doesnt work
ok..... firstly check to make sure the "NUM LOCK" is off!!! if no joy get a usb keyboard and restart the pc with keyboard plugged in, hopefully if the usb controllers are enabled in the bios you will be able use the usb keyboard and enter your password, use it until you resolve the issue
SOURCE: Bought new E525, cant get wireless networking to work
Some laptops have switches that you have to turn on manually in order ffor it to work look for a switch usually on bottom of the laptop under or near touchpad
When you boot up to the log in screen type in administrator as user if you cant log in
During the boot up process you will see on the screen for a short amount of time a certain key to enter set up press and hold that key to enter set up BIOS scroll to set user password or supervisor password you can change or remove the password from there if you are still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable "live" CD which contains software that allows you to change paswords repair/restore/diagnostic almost any computer problem also has a bios reset tool which remove your password and BIOS password although you will have to use a computer with an internet connection you will have to burn it to a disk as an iso then change your firtst boot device to cd During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed the password you must go back and change the first boot device to your hard drive)
Hope this helps
Hope this helps
if you are not the computer administrator and have not assigned a bios
password during the boot up process you will see on the screen for a short
amount of time press a certain key to enter set up Press and hold that key
during the boot up process to enter BIOS scroll down to set user password or
supervisor password you can change or remove your password from there also
click start control panel user
accounts on the users tab,click the name of the computer administrator you must
have full control can change the password there
Also
i have used this software and no that it works although
you might have to get a computer with an internet connection to download and
burn it to a disc
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains
software that allows you to repair, restore, or diagnose almost any computer
problem also has a bios reset tool which can remove your password and bios
password
a disk as an ISO then you will have to boot from the disc
to cmos to restart (note after you have removed your password you will have
change first boot back to your hard drive)
Hope this helps
When you boot up to the log in screen type in administrator to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
or
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
http://www.fixya.com/users/jack-baxter
