DOSENT POWER ON GREEN LIGHT JUST FLASHES
Dear Elvira,
You have to disconnet your power supply from the mains by pulling out power cord then the open the side pan of your cabinet and locate the ram.remove the ram and resit it in another slot. then connect your power cord to the power supply of your pc then switch on.
If the problem is not solved then again remove the power cord and remove the cmos battery from the motherboard and wait for 20 seconds,then put it back.and power on the system. if the problem is not solved then try with another powe supply.still problem is there then your motherboard may be bad.you have to replace the motherboard.
