I have an GE JGSP31GER Gas Oven, It does not heat up. I set the oven temperature to 450, but an oven thermometer says it is only at 200 degrees. I've also tried the broil on high and it also will only heat up until about 200 degrees then shuts down. If I open the oven door and let it cool for a minute, it will fire up again, but still stops around 200 degrees. I have already replaced the bake igniter and also the oven sensor already. What's next to try?
The part your talking about used to run about $275 which is pretty high for a free standing range but the cost of it isn't important. The reason why is that they no longer make that part anymore and when i looked it up I got NLA which means no longer available. You may get lucky and find a company that possibly has one still in stock, but there is no way that it will come with a warranty, so if its a dud when you get it your stuck with it. I would invest my money in something I could fix when it came time to.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
SOURCE: Oven not heating properly
Hello. You have done an excellent job of explaining your problem. Read over the info. below as it sounds like your top element is not working.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
SOURCE: My gas oven overheats and burns my baking. With
bad thermostat.....buy new at lowes .....its inside the oven.....usually at the top of oven..looks like copper rod with copper wire ....easy to change...buy at lowes or homedepot
SOURCE: GE Profile XL44 Spectra gas oven
My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! [email protected]
Someone suggested replacing the oven control board. How hard is this? Is it worth doing or just get a new oven?
