Red light then blue light from the side panel but nothing comes on
SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central
2. Settings
3. Remote Control
4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
SOURCE: Tv doesnot power on
two options _bad backlight inverter or the main board ;eed to be change.
SOURCE: My polaroid TV will turn on but there is no picture or sound
blown caps in the power supply a 470m at 16 volt cap it will be puffed up
Testimonial: "You were right. It was blown 1000uf caps. Great job. Thank you very much"
SOURCE: Blue LED light comes on but nothing else happens when turned on
It can be the main board or the power supply,
look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find
SOURCE: My Polaroid TV TDA-03211C will not turn on. It has
power supply problem bad capacitors the red light is power to check cap inside
