My sandisk 16 cruzer's light is not showing and the pc doesn't detect it
Try the flash drive in another computer, and if the problem is still there, the product may be corrupted.
If the product is still in it's warranty period, you should go to the manufacturer's service center, and they will replace it free of cost.
If the warranty period is over, just buy a new one.
Hope this helps, Mrityunjay.
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you restore it to its default status
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
SOURCE: Can't open my sandisk cruzer 16gb
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
SOURCE: I have a cruzer micro 16Gb flash drive with 14.9Gb
Did you reformat as NTFS instead of the default FAT32? FAT32 can only transfer files up to 4.0Gb in size. If you reformat as NTFS, you can move larger files.
SOURCE: sandisk 4GB cruzer micro usb
Are you connecting it to the back of your computer? Sometimes the port in front does not have enough power to power it on.Also please try another computer
SOURCE: Sandisk Cruzer 8gb Error
Make sure you are logged in as an administrator. I'd also try the thumb drive in a different computer just to make sure the problem isn't with the thumb drive itself. The drive could also be unformatted, or formatted with a filesystem for a different platform that can't be read by XP.
SOURCE: Sandisk cruzer 16gb, Macformat, tv won't recognize
Dowload codec Klite pack, via Google, and open the files with that media player, the tv should then pick it up, seeing as its a multi codec reader program, Hope it helps
Mine too gues what we both might be screwed and we cannot say we enjoyed it, I have a wildhare though perhaps if we got a new one took the card out the old one and put it in the new one we might be able to get our data back., oh yea no ligh mean the stick may be damaged
