2wire 2700HG-B Router (2700HGB) Logo
Posted on Jun 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does WPA key mean on psp
I try to connect internet to my psp but every time it comes to WPA key i mess up and i cant figure out what it means
John Anderson
Level 2:
Sergeant:
  • Expert 310 Answers
  • Posted on Jun 19, 2012
John Anderson
Expert
Level 2:
Sergeant:
Answers
310
Questions
Helped
148143
Points
659
It means Wi-Fi Protected Access, its asking you for a wireless key for a wireless network to connect the device to the internet.
Cant connect to the internet
You did not elaborate further why you cannot connect you PSP to internet. But I will assume that you have a wireless connection within reach and that your PSP Wi-Fi switch is turned on (switch on the right).
1.) If your wireless network requires a Network Key (WEP or WPA), you need to know the exact key to be able to connect to it. 2.) To connect to internet, open Internet Browser in your PSP and this will prompt you to connect to a Wireless network. 3.) To set-up, press the 'scroll right' button (>) until you reach the "Network Key". Choose the type of key your network is using (WEP, WPA or other) then press 'scroll right' (>) again until you reach the last menu. 4.) If you do not encounter any error, you can start browsing. If you still do, you may have to leave the specific errors or further details of your problem for us to assess...
P.S. My favorite is God of War (I hope you have tried playing it)...
I have a PSP 1001 and i can't find the error code 80410E80 whut dose it mean and why cant i connect to my wierless router witch is 2 feet away from me and the psp keeps timing out after a min or two...
Sounds like there is something going on with the security key which is usually WEP or WPA and the psp may not be accepting it. Make sure on your wireless router that you don't have a key enabled on it. Best best on most routers. Hold down the reset button for 30 seconds and let go, this will reset your router to factory defaults.
Now that your router has no security on it. Try connecting the PSP to the router again. If it connects then you know the security key was corrupt. Now you can go ahead and put the security key back in. Make sure your PSP is configured to use the key so it can connect.
1helpful
My psp always says connection has timed out check for wpa key
You would need to enter the WPA that is being used by your router. This is like a "password" of sorts that prevents other people from using your internet connection without your permission. Once you find out the WPA key (it should be in your router's configuration), you can either disable WPA on your router, or enter it into your PSP.
1helpful
I just bought a psp go and it's asking for wpa key, what does thhat mean and how do I find it?
The WPA key is related to the router used for the wireless connection to your PSP. If you go to the security menu and enter your routers WPS code, you should be ready! (The code should be available from your internet provider if you don't have it handy.)
I do not know how to find my wpa key for my psp
i suggest turning off the wpa security thing, to do this type 192.168.1.1 or 192.168.1.0 in your internet browser on ur computer. every wireless network databass is different. the first 7 digits number are the same. for example every network databass starts with 192.168.1 and the last digit is different. if u try the ip i gave u above and it still doesnt work.play with the ip thing by switching the last digit to 1 through 10. for example: 192.168.1.2 and 192.168.1.3 and so forth, then try connecting it to the network. o yea..... in order to gain access to the databass, u will have to be administrator which u can obtain it from ur internet provider, just type in admin in both username and password
1. Disable the security features. (this means that you don't have to enter any password when connecting PSP to the router)
2. Reconfigure your PSP: no security
3. Test your connection
2answers
Trying to get on internet but its asking for a wep key or a wpa key I just completed hook up to netgear router have desk top and a wirerles lap top laptop is asking for info
The WEP and WPA key is configured in the router's wireless settings.
WPA is a stronger encryption than the older WEP encryption, I suggest you use WPA or better still WPA2.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
2answers
Psp problem
means the wep key you are entering is most likely incorrect. Go into your router settings check somewhere under wifi or wifi security. You will say it says wep or wpa look at the code that is on that screen and enter it in your psp. That should be the fix that you are looking for.
3answers
Cant get may psp and my wii consoles to work
This is the password to your wireless network.
1helpful
6answers
Psp no connection to internet
Why can't I connect to the internet on my psp I tried over & over nothing it says the connection to the acces point has timed out..
i still can't connect even with wireless router
Top 2wire Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
