Husband moved washer last night. Now when I tried to start a cycle with the button, got an error code E. Selected a different cycle and it worked for a while then stopped and got the E02 code.
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
Begin your pump cleaning procedure by first disconnecting the power and turning the water supply lines off.
To properly remove the access panel, find a very small slotted (flat bladed) screwdriver that will fit easily into the hole in the access panel.
GENTLY push in ever so slightly and rotate the access panel CLOCKWISE. The panel will fall away and you will now see inside the unit a rather large handle.
NOTE: BEFORE removing the pump drain get yourself a towel to catch the water that will come spilling out of the pump housing. There is a good amount of water, nearly a 1 litre / 1 quart.
Grasp the handle and rotate it COUNTER-CLOCKWISE. The water in the pump will drain out, as will any lint or debris material in this filter unit.
Using an CLEAN rag, proceed to wipe out the interior of the housing. Any material that builds up in here can be a source for odors left in your clothing. It is a good idea to clean this housing at least 1 or 2 times per year, depending on how much use your units gets. The more loads per week, especially if you have a rather large family, you might consider doing this cleaning 4 times a year with the changing of the seasons.
You will also need to clean the filter plug. Be careful not to damage the rubber gasket, if you damage the gasket the housing will leak.
When everything is clean, re-install the filter plug, DO NOT OVER TIGHTEN! Re-install the access panel. Turn on the water supply lines and replug the AC line into the wall outlet.
Run a Quick Wash cycle to clean out the pump of any other loosened materials.
Hope this helps everyone out.
Cheers,
Keith
E02 seems to be that the water lines coming in (either hot, cold, or both) are either blocked or turned off. Basically the machine isn't getting any incoming water.
OK, so the filter behind te little round door at the bottom right of the machine mau be clogged. How do I open the door? There is no mention of how to do this in the manual, and it doesn't just pry off (easily). There is a small hole in it (about the 5 o'clock position) that I have probed and there is something springy behind it, but pushing on it doesn't seem to release anything. I guerss I could force/pry it off, but that'd probably break it and I don't want to do that.
Hi whats the problem when this message appear on the bosch washing machine screen nr0
thanks
This door turns and the comes off.
error pops up after running a few minutes
code e02
what is aqua stop activaited code
on a bosch 800 ser.
Error codes e02 and f08 keep coming up
