Hello you can download the manual, and drivers here:
http://www.gigabyte.com/products/product-page.aspx?pid=1810#manual
You can add a graphic card 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
And Max capacity: Up to 2GB DDR400 RAM by 2 DIMM slots.
ATI/AMD makes very good graphic cards.
Adding a graphic card on the mainboard will not slow the physical memory. It has it`s own ram.
Good luck
SOURCE: GA-K8VM800M and GV-N76G256D-RH compatibility
Perhaps your power supply is not powerful enough for the new card.
SOURCE: needs video drivers for GA-k8vm800m
http://www.driverstock.com/download-GigaByte-GA-K8VM800M-driver/30-9-8096/index.html
SOURCE: Gigabyte GA-8VM800M 478 - On-board VGA as well as ASUS N6200 vid card
this can support two monitors. but it means one through the dvi output and one through the analog and have the desktop spread over two screens..If you need help locating these ports then ask me..
SOURCE: I need audio driver Gigabyte GA K8VM800M" Can you give me ?
No, we cant. But Gigabyte can.
http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=1919
SOURCE: Can Gigabyte GA-8I945PLGE-RH supports 4gb ram?
Sorry, but at the moment you can't do that. This is because the BIOS is programmed to manage only 2GB memory. I searched for BIOS upgrade to resolve the memory issue but with no luck. At the moment your motherboard supports only 2 GB RAM.
