Hello Sara,
I think you have a gasoven too?
in that case I think it is the flame safety device.
when that is gone, the burner goes on very low, although it looks like all went well.
It looks like the one I send you in the link, it is on the side of the oven burner.
I hpe this helps you, kind regards, Dik
Electrolux Tricity Bendix Oven Safety Device HG Fsd Solenoid 359070604...
SOURCE: Oven stops cooking, control panel says it's still on
Sounds like the igniter is going or has gone. In modern stoves there is no pilot light. The gas is ignited via a high temperature igniter. Over the years I've had a couple of them go out. The symptoms are identical to what you're seeing. Pull out all of the shelves and to bottom tray (covering the burners). You'll probably need a screw driver to get the tray out. You will see a curious looking device with wires running into it. That's the igniter. Do a Google search and identify the part, order it and replace it.
