I need to replace the rubber gastket part of the door on a front loading Indesit WIA 101 washing machine (Italian model). The gasket was damaged and has a big slash right in the middle. As a result, the door leaks during washing. I cannot find a replacement part, ANYWHERE! I would be most grateful if you could please help me....
Bottom of front right door of shed damaged at right lower corner. Can I get a replacement door??Bottom of front right door of shed damaged at right lower corner. Can I get a replacement door??
You can't post conmments that contain an email address.
For Genuine Indesit Gaskets & Seals you've come to the right place. Restore your appliance with our huge selection of parts. Next day delivery available.
How to Replace an Indesit Washing Machine Door Seal · Step 1 - Safety Advice · Step 2 - Decide How You Want To Replace The Door Gasket · Step 3 - Remove ...
HI, Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped. If no water then the Pump may need replaced Thank you for using fixya Leo Ponder Please rate me if this helped
Sam. The small nut and bolt which protrudes between the element ends should be loosened but not taken off. Press on the bolt, which will relax the compression on the rubber sealing block. This should allow you to extract the element. Once you have done this it will become clear..
At first thought it was door lock mechanism was at fault but proved it to be ok - removed rubber 'boot' which on this model was on two stretchable spring retainers and checked operation of door lock.
Thought door hinges may have been bent so dismantled door, finding the problem to be the pin that the door latch pivots on had come out on one side so not lining up properly. This was easily pushed back into position.
undo clamp holding door gasket on cabinet and peel gasket back in the area of the door catch.
door lock is just held in by 2 screws from the outside and will come away when these are undone. on some models, there is also a small diameter pipe going to the door lock and take this off. note where wires go before removing them
