SOURCE: grinding noise on startup
Problem
The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise.
Solution
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cable from the back of the printer when the grinding noise starts.
4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
5. Take out the cartridges and close the top cover. Turn the printer back on!
6. Reconnect the power cord.
7. Open the top cover, reinstall the cartridges, and then close the top cover
SOURCE: just stoped printing;print cartridge problem
Remove print catrige and clean it with cotton cloth then refix it.
SOURCE: HP Officejet printer, says cartridges are missing or not detected
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr11
SOURCE: I have a hp officejet j4540 and I lost my install
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3645094&lc=en&cc=us&dlc=en&lang=en&cc=us
click on the above link and select the operating system installed on your computer & click on full featured software and drivers
SOURCE: HP Officejet Pro 8500 Wireless
Hi. You leave a question mark?
I don't understsand what you mean by Papaer feed will not "DROP DOWN"?
I to have the same printer, the paper feeds from the tray (s) from below.
A little more info please?
The grinding in the system trying to feed through the paper.
Just a thought, turn the printer round find the release levers and check the internals for paper jam.
