I wasable to pairmy iPad withy blackberry, but where do I find the import function? What are the steps to import my address book from the blackberry to the iPad?
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.
I'm Ben and -- hopefully -- I can provide some meaningful assistance.
The following sounds complicated but it is very easy if you carefully follow the instructions.
Unfortunately, there is no cable to connect the BlackBerry and iPhone together and a user can't transfer BlackBerry contacts to iPhone directly via USB cable. So, we should export contacts out of BlackBerry and save onto a program, then import the contacts from the program to iPhone.
Things you'll need to transfer BlackBerry contacts to iPhone.
If you are the first time using Google Sync on BlackBerry. all the contacts from your blackBerry are saved to your Gmail contacts in a group called My Contacts.
Please login your Gmail and Go to "Contacts" option on the left of Gmail account.
Then you'll see a "more" menu. Click it and you'll see a drop-down menu.
Select "Export" contacts.
There are three models to export contacts out of Google account.
1. Export Group "My contacts" to Google CSV format.
Export Google contacts as csv
2. Export Group "My contacts" to Outlook CSV format. Export Google Contacts to Outlook CSV
3. Export Group "My contacts" to vCard format. So that you can import the contacts to Apple Address book or iOS devices.Such as import to iPhone, iPod touch, iPad. Export Group "My contacts" to vCard format
Now, import vCard file to iPhone
You can save the Google account contacts to computer as vCard file and download this iPhone contacts transfer program.
You may be familiar with cloud services, such as Dropbox, iCloud and so on. You can take advantage of Dropbox to sync contacts between BlackBerry phone and iPad.
If you're using Gmail as your primary account on BlackBerry, your address book and calendar should be ready to pull down to iOS with minimal effort - iCloud can handle all of that stuff too. If you're using contacts on another service, like Yahoo! or Exchange, the situation is similar.
Both methods can be helpful if you want to move contacts from BlackBerry to iPad, and they're totally free.
Three Simple Methods to Transfer Contacts from BlackBerry to iPhone 6 6s SE
This a guide that might help you to get BlackBerry contacts to iPhone 6s. How to Transfer Contacts and SMS from BlackBerry to iPhone
You may also follow it to make it on your iPad.
Remember download the transfer first: Phone Transfer.
Hello, may be you can choose to use a professional transfer tool named Phone toPhone Transfer.
Phone to Phone Transfer - One Click to Transfer Contacts and SMS from BlackBerry to iPhone. You would need a computer in order to effectuate the transer. With the Phone to Phone Transfer, you can transfer business contacts and personal contacts and SMS from BlackBerry to iPhone, which works for iOS 7 and earlier version of iOS too. The program compatible with the backup files of BlackBerry phones running OS 7.1 and earlier. 1. Download the BlackBerry Desktop Manager on your computer, and connect your BlackBerry 2. Transfer your BlackBerry contacts to your computer via the BB Desktop Manager 3. Follow these directions in order to transfer the BlackBerry contacts and SMS to your iPhone http://datas-recovery.com/static/copy-bl...
SOURCE: Phone Book Transfer Nokia N70 - Blackberry 9000
Syncronization! The Nokia phone will not just easily transfer or sync the contacts to your Black Berry because they are running on 2 different softwares.
In order for you to transfer all the contacts to your Black Berry is through synchronization
The Nokia N70 came with a CD called the Nokia PC Suite. And Black Berry should have a sync software.
What are the things you need:
1. Computer
2. Nokia N70
3. Black Berry phone
4. Nokia PC Suite CD
5. Black Berry sync software
How:
1. Install the Nokia PC suite to the computer.
2. Connect the Nokia N70 to the computer.
3. Export all the Contacts from Nokia N70 to your computer (refer to the manual)
4. Once the contacts are saved in your computer, disconnect the Nokia and connect your Black Berry.
5. Run the sync software of Black Berry and import the Contacts that are saved in the computer going to your Black Berry (refer to the manual of Black berry).
This is hiow to transfer the contacts from one phone to another.
I would also suggest to contact Nokia so that you will have a clearer idea on how to do it.
SOURCE: i can not see my imported sim contacts in my phone book.
To see the sim contacts in the phone contacts or adress book .You have to follow the below steps
