My Samsung TV is making clicking noises (specifically the Digital Video Output (Optical) and the TV won't turn on. Please help
SOURCE: Samsung LNT4061FX makes clicking noise before coming on.
Replace capacitors in power supply you will see that they are bulged on top
SOURCE: my 5 year old samsung flat tv will not turn on
probably the power supply and could also be the L-main board
SOURCE: my samsung plasma tv went out and it just makes a
It was not your power board, Thought the same on several repairs.Found out it was the main board. The clicking was the tuner relay. I bet you own a SP-R4232. If so,The part you need is BN41-00574A. Also might be under BN94-00669A. Hard to find. Try Shop Jimmy/Or Encompass Parts. Not cheep tho. Hope this info helps.
Have a happy new year. Todd
SOURCE: samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
sq01 won't turn on
