Televison & Video Logo
Posted on Jun 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Program my remote - Zenith Televison & Video
Level 3:
Top Expert:
  • Zenith Master 76,851 Answers
  • Posted on Jun 17, 2012
Zenith Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005729
Points
237762
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
2answers
Code for programming to a LG 4K tv?
  1. LG UHD 4K Television - LG.com‎
    Adwww.lg.com/UltraHD4KTVRatings:Reliability 9.5/10 - Picture quality 9.5/10 - Features 9.5/10
Search Results
    Find Your Comcast Remote Control Programming Code
    customer.xfinity.com/...tv/finding-your-remote-control-programming-co...
    Learn Comcast remote codes and more information on how to program your remote control. ... To Watch On Demand Programming with XFINITY TV:.
    DIRECTV - Remote Control Code Lookup
2answers
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
1helpful
2answers
2answers
Program RCA universal remote with Panasonic TV
If you have the owner manual for the remote try all the panasonic codes or google for that with the model number of the remote--not all remotes will program for all models and if programs it may be missing key features the original remote had.
2answers
How do you re-program a remote to a television?
Check online. Go to google type in what kinda of remote it is. Type in program codes for ''''''' your remote''''' and instructions on re-programming. They usually have all the guides online for the remote controls.
2answers
I'm trying to program my sansui tv with my universal remote
Instructions for programming your RCR311B can be found here ...
http://audiovox2.info/docs/rca_acc/man/RCR311BN_DOC_OM.PDF
Can only program one remote or keypad. which ever
You are going to have to do a process of elimination. I think you have either a bad remote or a bad keypad. Try programming a remote and then the keypad. If only one works then go with the other remote and the keypad. If only one works then program the two remotes. If the two remotes work then the keypad is bad or if you can program one remote and the keypad then the other remote is bad. Get rid of the bad one.
8helpful
2answers
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
