Trying to replace the capaitors
SOURCE: green blinking light problem too. on a Mitsubishi WS65869
You can go to this link they have the kits with the high temp higher volt capacitors and complete detailed instructions on how to do the repair.
http://servicemanuals.vstore.ca/
SOURCE: Mitsubishi WD62526 - Error/repair code
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
remove the back and lamp (make sure the lamp door is on) turn the tv on and look to see if the fan is running (keep you hand out of the tv when doing this - as the lamp connectors are empty) if the fan does not start - replace lamp - the connector is located under lamp housing connector JA - measure the red wire and ground (any metal part) for 12v at turn on - if 12v replace fan - if no 12v check the power pcb
SOURCE: Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
SOURCE: want to replace caps which board is the DM board?
Once you take the shield assembly off, you will see a board, I believe it is the DM Board board. There are four Capacitors grouped together probably rated at 35v 1000 mfd, 105 degree. They should be replaced with 35v 680mfd,105 degree Capacitors. Now once that is done, there is another board under that one. This is the Format Board. It also has 4 Capacitors that should also be replaced. They are the same value as the first Board and should be replaced with the same 35v 680mfd, 105 degree Capacitors.
Please note the Flex connectors at the bottom of the DM and Format Boards. They may not be available from Mitsubishi any more so be gentle with them and make sure the are installed properly when reinstalling the Boards back into the chassis. There is one other Board you should look at. The Power Supply Board is the board on the back of the chassis and also has a number of Capacitors that fail. Most all of the Capacitors that fail through out this chassis will have bulging tops. So any you see bulging, you should replace whether they are on the DM, Format , or Power Supply.
I hope this helps,
Skyassoc
