I have descaled and "clean" is still present on panel. Not flashing just there all the time. Read the manual and gives me the impression should show on panel only if needs cleaning.
I found that the following clears the "clean" word that is flashing:
Hopefully, the clean message will go off.
As an aside, the warmer plate is so awful looking. I am replacing this coffee maker (KM222) with another (and cheaper) one.
SOURCE: Solis Palazzo Descaling (?) Problem? Please Help!
Hi
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
SOURCE: HOW DO I RESET CLEAN LIGHT?
Unplug the unit for 30 minutes or longer - it should reset the coffeemaker and the clean light.
SOURCE: self cleaning coffee maker
Unplug the coffeemaker for one full hour, and the self-cleaning light will go off.
SOURCE: clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
SOURCE: The red light is flashing saying I should clean
Pour two cups vinegar through and then flush it with two runs of fresh water
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
