When connecting to to comp via usb scree (on laptop ) warns of bad drive and check disc req however will no t allow to proceed as addirional warning states cannot check whilst in use?
SOURCE: my archos 605 not showing on my laptop
hi, u may have to install the drivers fitting your windows version from the (mini)cd u purchased with it. if you don|t have it, goto the manufacturers hp and download drivers as well as data manager program for your player
at:
http://www.archos.com/support/support_tech
good luck
SOURCE: Archos won't connect by USB to computers
You should keep your eye on the device after its been plugged to the PC it will give you 2 options "charge" or "usb" you ca not establish a connection without picking usb connection option on the Archos screen when it pops up. If you are doing so and problem still existed then i would recommend you to download the latest windows media player. Because it comes with new devices sync driver update.
SOURCE: how do i solve the problem with the archos 3
Get a pin and reset using the little hole on the rear bottom cover.
SOURCE: How do i transfer from itunes to my archos 3 vision
Archos 3 will not play DRM protected songs. You may need to find a converter. I don't know if this is possible.
SOURCE: my archos 3 vision screen has frozen how do i fix ...
press the reset button in the back with a pin or small pen, hold for 10 s or so.
