When watching I get double images...then it will be fine for a couple of minutes...then it goes back to the double images. This first started a couple of weeks ago and the double images only occurred when I turned it on. After about 5 minutes it would be fine.
It has now started shutting off. It stays on for about 5 minutes then shuts itself off.
Unpug tv remove rear panel inside will be a large circuit board with a connector on either side which control the left and right of tv, carefully unclip the left side clip, place a small strip of clear celotape (10x20mm) to the left side of left connector, plug in and recheck, some tweaking may be required. Repeat on rhs if required
There maybe some loose components on the circuit and that needs resoldering. Bring it to the repair shop to done.
