A
Anonymous Posted on Jun 15, 2012
How do I fix error 571 on my 9800 monarch ticket machine using my loftware 32 design ticket?
Torsten Pihl
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 15, 2014
Torsten Pihl
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3828
Points
If you are getting error 571 from Nebraska Book Company's WinPrism inventory control system, File --> System Settings --> set the Receipt Type to 8-1/2 X 11. It seems irrelevant but it works.
Another possible resolution to the problem is to remove the Windows (XP, 7, 8, 10) profile of the offending user:
0. Login as the offending user and backup anything they want to keep, like browser bookmarks/favorite or documents on the desktop.
1. Log into Windows as a local administrator.
2. Control Panel --> User Accounts --> select the offending user --> Remove.
3. Restart.
4. Log into Windows as a local administrator.
5. Delete C:\Users\offending_user
6. The following is necessary to avoid a "temporary profile" error: Regedit.exe HKEY_LOCAL_MACHINE --> Software --> Microsoft --> Windows NT --> Current Version --> ProfileList --> select each entry until you find the one with a ProfileImagePath of C:\Users\offending_user and delete it.
7. Control Panel --> User Accounts --> add the user.
8. Login as the offending user, add the printer, and now it should work.
1 Related Answer
Anonymous
  • Posted on May 12, 2010
SOURCE: Dymo Labelwriter 400 print ticket error??
https://dymo.custhelp.com/app/answers/detail/a_id/1343/~/failed-to-convert-devmode-to-print-ticket-error-when-printing-from-dymo-label
The Monarch 9403 does not print out multiples of labels continuously, it stops between each single label. Can you help? Cheers Debbie
Debbie,
I may need a little more information.
If you are using a 3rd part software application like that from Loftware, you may need to create your labels in such a manner that the print module prints strips of labels, and in the quantity that you need. Then the printer should produce the quantity each time you go to print.
If you are using a 3rd party driver, like that from Seagull Scientific, then you need to tell it to print that quantity, just like you would when printing something on your inkjet printer.
If you are sending the printer's native language directly to the printer, there is something called the format header. It looks something like this:
{B,1,N,1|
The second 1, is the quantity of labels. So if you want it to print 5, you need to change it to something like...
{B,1,N,5|
If neither of these make sense, please provide some additional details so that I may provide further assistance.
2answers
I need speedy label software for Windows XP This used to ship with paxar monarch printers. The earlier version works only on Win98 Can anyone provide me this ?
You can open up label templates in Word or other word processors. For Word, you can find these on Microsoft's website for free generally.
If you are using Avery labels, they have their own label software package custom designed for their products here: http://www.avery.com/avery/en_us/Templates-%26-Software/Software/Avery-Wizard-for-Microsoft-Office.htm
1helpful
Datawatch Monarch NTDLL.DLL Failure
Waiting on information from Monarch software.
3answers
Monarch Paxar 9855 Printing Errors
can you try a serial connection, what type of operating system are you using?
2answers
Error Msg. "755" on Monarch 9830
if you look carefully there si a small magnet that touches another while when the printhead is closed which is known a sensor. when these to meet it tells the machine that indeed the print head is closed. lots of times one of these 'magnets' fall out and which fails to create the signal that the printer is closed
see if you can locate the area and inspect it
2answers
Left side of roll ticket doesn't print.
You have a bad printhead. Shut off the printer and as it reboots check out the display. It'll probably flash "765 printhead error" as it boots up.
The printhead needs to be replaced.
k24674
ADMIN Andrew
ADMIN Andrew
