SOURCE: frigidaire dryer error E4A
This is this is the "program Timeout Fault". Meaning the drying time has exceeded program time for that cycle.Press Pause Cancel and SELECT buttons for 6
seconds to exit test modes. Position cycle selector to NORMAL,
temperature selector to HIGH HEAT and touch START. Check for anything
that would extend dry times such as: no heat, restricted vent, blower
fan blade broken or loose, dryer installed in closet with solid door,
or bad connection in moisture sensor bar circuit or dirty bars. If
dryer operates normally but code returns, replace electronic control.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
error code 61 shows up on our new affinity dryer and it is not heating up
CODE E05
My dryer is LOUD! Is it going out or is something loose?
