Unit fills and will drain. Pump hums when should be washing. No spray.
SOURCE: kitchenaid dishwashes makes wining noise during wash
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
SOURCE: dishwasher fills but does not wash
Is your Kitchenaid Dishwasher a model KUDI02?
If yes, you need to order item 10 on the page link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137276
Good Luck!
SOURCE: Heating element circut malfunction In Dishwasher. Wash not workin
Great job walking through the possible causes! Hey, it is time to check the heating element itself. First visually, looking for brakes and then feeling for "bubbles" on the round element rod. Also see if it moves excessivly when you wiggle.
If no problem obvious, after you disconnect the dishwasher from power, use a multimeter to check for resistance (Ohms) If none, look for broken (heavy guage) wires and replace what's broken - probably the element itself.
If the element checks out good, suspect the thermistor then the controller/PCB.
Good Luck! Please report back what you find, OK?
SOURCE: Our Kitchenaid kuds25se fills with water but won't wash or drain.
i would check the check valve ....i had the same issue and the info within below link got be up and running again
http://fixitnow.com/wp/2008/11/14/older-whirlpool-kenmore-dishwasher-wont-drain/
SOURCE: Kitchenaid dishwasher will not turn on or drain
Float valve is jammed.
Look inside the machine on the floor will
be a small float valve. Looks like a small upside down cup. Lift it and
clear anything from underneath.
The valve is a safety feature
to stop the machine from over filling. If anything gets under the valve
it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop
as much water our as you can. Open the cover on the floor of the
machine. Usually just turns and lifts out or snaps out some are screwed
in. Take your time and try not to force anything. Look for a clog
there.
Check for clog in the drain. The dishwasher will
connect to the drain under your sink and run either directly to the
drain or into your disposal unit. Remove open the connections and look
for a clog. Clear if necessary.
Not the clog?
Water is
pumped out by the machine via an internal pump located under the base.
If it fails the water will collect until it trips the float valve.
First scoop out all the water from the machine and run it again. If
water comes in and it runs to the point it fills again and trips the
float then either the pump or timer is faulty.
Pump check.
Remove
the machine. It will be held in place by screws directly into the
counter top. You may have to lower it to get it out. The front feet
turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect
a test light or voltage tester to the terminals at the pump. Check for
voltage at the pump. If you have voltage replace the pump. If no
voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For
more help go to my more detailed tip "Dishwasher will not run. DW101
how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
