Nikon Coolpix L24 Silver Digital Camera 8gb Kit Logo
Arlene Lee Posted on Jun 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I put pictures on a dvd from nikon coolpix L24
All I am trying to do is save pictures from camera to a dvd
Nanny
Level 3:
Genius:
  • Nikon Master 2,351 Answers
  • Posted on Jul 18, 2019
Nanny
Nikon Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
988553
Points
7262
There are some photo slideshow creating applicationsand the creating process is not that complicated.
Burn Slideshow to DVD on Windows DVD Maker
1. Launch Windows DVD Maker
2. Click "Add Items" button to browse and add your photos or photo slideshow videos. Then click "Next" button.
3. You could select a disc menu and customize it if you like. Adding your favorite song as background music is allowed.
4. Insert blank writable DVD disc into the recorder drive. Click the "Burn" button to start burning photo slideshow to blank DVD disc.
And then you could use Leawo DVD Creator to burn the slideshow to DVD discs.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
776
Points
First you need to convert the photos to pc with the usb cable,
then use a tool to burn the photos to DVD,such as DVD Photo Slideshow,or Windows DVD Maker.
This is an article about burn Nikon camera photos to DVD and enjoy it on TV,http://www.dvd-photo-slideshow.com/burn-nikon-camera-photo-to-dvd.html
Hope it can help
Anonymous
Level 3:
  • Nikon Master 32,281 Answers
  • Posted on Jun 16, 2012
Anonymous
Nikon Master
Level 3:
Answers
32281
Questions
Helped
7905732
Points
102259
First you need to copy the photos to your computer that has a DVD burner. Then you open the DVD burn program and select the photos to burn onto the DVD disc.
5 Related Answers
Anonymous
  • 32281 Answers
  • Posted on Jan 05, 2009
SOURCE: nikon transfer is not showing that my camera is connected
There is an alternate way of downloading images from the memory card from the camera.
Get a USB memory card reader, remove the memory card from the camera, insert it into the card reader, then plug the card reader into the USB port of your computer. You will now see card reader as an external memory device, open the folder and copy your photos onto your hard drive.
Anonymous
  • Posted on Feb 12, 2009
SOURCE: nikon coolpix S6 screen black
All you have to do is lay your camera with the LCD side down, make sure its on a soft surface like a carpet or a pillow. Once you have it laying down, put a peice or two of newspaper, or any paper, on top of the camera. and then hit it a few times with something. like a brush or anything hard like that. it worked for me. :) good luck.
Anonymous
  • 744 Answers
  • Posted on Jun 28, 2009
SOURCE: flash on Nikon Coolpix s200 camera not working
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Anonymous
  • Posted on Sep 13, 2009
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Anonymous
  • Posted on Nov 14, 2009
SOURCE: Out of memory on Nikon Coolpix L18 camera
I noticed that, after dumping the full SD card onto my computer, I didn't seat it perfectly back in the camera (my finger bottomed out on the batteries before the memory card 'clicked' into place. With the camera unable to see the SD card, it defaulted to the internal memory, which is very small.
I got the SD card seated fully and the "Out of Memory" message went away.
Battery door replacement on L24
These battery doors need delicate handling. These can be ordered on ebay and replaceable by user.
Monitor screen is black cannot see anything on the monitor
If the screen is black even when you press the menu button or switch to playback, than it's probably because of a defective LCD display. Anybody with basic repair skills and experience would be able to replace the lcd display with a new one. Try to find a display specifically for a L24 camera on ebay or elsewhere. There might also be a few video's on the internet how t disassembly this camera.
Nikon Coolpix L24 camera. It doesn't take pictures. I mean that camera turns on nicely, the lens unfolds, you can even view images that you previously took, but when you press the button to take new photo,...
Check that your digital camera is not in playback or review mode.
Make sure the memory card is in the camera and that the card is properly formatted.
The Memory Card may be full. Download the images to the computer or delete some to make way for new photos.
Check the charge on the batteries. Replace if necessary.
Have you been using the flash? It may be recharging. When it is recharged, the camera will be ready to take photos again.
My camera says battery exhausted but I put new batteries in and get the same message
Better you can give it in near service Center..because look like some shortage is there inside your camera..(small problem only )..otherwise.. it won't show like that...
2helpful
Coolpix L24 manual
You may download a copy of the manual from here.
I have a Nikon coolpix L24 camera but pc does not recognize camera when I try to download
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
THE BATTERY DOOR IN A NIKON COOLPIX L24 WONT CLOSE
This is a clear design flaw. There are hundreds of similar incidents. Just try searching for "Coolpix L22 battery door" Nikon refused even to sell me a replacement door, and asked me to send the whole camera to them for evaluation. Dozens of sellers on ebay and ali-express are selling the replacement door, but not Nikon-USA. They do not sell it. So beware when working with Nikon that they do not stand behind their products.
1helpful
Just got a coolpix L24 , previously had coolpix 4100, Was wondering if the old computer disc setup would still work on the new L24, probably not i would guess. I have many pictures on the computer I...
Sure, the old software will continue to work just fine. If you want to update it, you can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
Is it worth fixing a broken LCD Screen on a Nikon Coolpix L18
That's up to you, of course. You can get a new screen here, but the cost is about the same as a used L18, and not that much less than a new L22 or L24. If it was me, I'd replace the L18 instead of repairing it.
Pictures stuck in transfer; everything greyed out
Put the card in a card reader and download the pics.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
