SOURCE: like to know more about my rolex daytona?
The daytona you describe that has 24 hours at Daytona on the back is a relatively cheap replica daytona. It probably has a 21J japanese or chinese movement, and will probably not last very long under normal wear. The better ones out there are about $100, but you can get them for much less. The chronos do not function as the genuine daytona. The move and measure something, but who knows what.
So, this is a cheap imitation of the rolex daytona, and by no means is the best replica out there. There are better ones available with asian copies of the valjoux 7750 movement. These movements also vary in quality from the cheaper ones that run at 21,600bph, or the more upgraded mov'ts @28800bph. These have the running seconds at 6 position and hours at the 9 position.
You can search the web for a dealer that sells these better daytonas. Prices van start at around $190.00 and run up to more than $650.00 for the same watch and mov't. Depends on the dealer.. So, shop with knowledge and ask many questions before you ever purchase. You can get a reliable replica with automatic movement, depending on what model you're looking for... for less than $300. The SS series 116520 you can get a genuine looking replica for $140 to $223.
E-mail me personally and I'll tell you how to get information on ordering this Daytona replica.
Regards,
doug
SOURCE: rolex daytona
Rolex does not engrave the case back. If it says 24 hours at Daytona, or wording like that, the watch is not real... It's a fake, or as we say more kindly.. It's a replica, and can be bought on any replica watch web site for $30 to $80, for an automatic mov't., 21J, made in China.
Also, the sub-dials will not function on this watch. A Daytona needs the proper movement to operate the chronograph as it was intended..... To act as a stopwatch.. and measure time... seconds, minutes and hours. This is done by activating pushers at 2 and 4 positions, and the pushers on 21J replicas just don't operate a chron. for the purpose of measuring time. They may move and measure something else, like military time, or the date, but definitely not record seconds, minutes or hours.
There are also no manuals on how to operate the Daytona that comes with these replica watches. You should know how this watch functions and how to operate the pushers, and what they do before you should buy and enjoy this type of chronograph watch. It's simple, just take the time to ask people in the know... how the daytona works, what the sub-dials measure and how to use them, etc. In no time you'll understand the operation of this beautifully made watch. Unfortunately, a daytona is out of reach for most of us... That's why seeking out a quality rolex replica for much less money is the way to go if you love this watch... A quality one can look, feel, and function just as good as the authentic Daytona, and you won't have to out out over $10K to get one.
Regards,
Doug
Doug
SOURCE: 1992 daytona series rolex ( real ? )
This is one sign it maybe real. Everything from the solid headpieces, double steel pins, crew together band, gas relief valve, etc. can be signs that this is a real Rolex. Your best bet is always to go to a Rolex dealer or qualified watch maker/technician for an inspection. Good luck!
SOURCE: My Daytona Watch: On the back
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
