I have received a fax which is in the Fax Memory and I want to print it, how do I do this?
Press [START/MEMORY] and the stored documents will automatically print out. If you need the step by step owners manual with pictures, please send me an email to [email protected]. Please put "sharp ux b700" as the subject.
SOURCE: How to clear Memory in Sharp UXP115
FIRST:1-PRESS START/MEMORY KEY IF YOU WANT TO TRANSMIT THE PAGES WHICH STORED UP TO THAT POINT IN MEMORY THE REMAINING PAGES WILL BE REJECTED FROM THE FEEDER.AFTER TANSMISSION THE MEMORY WILL BE CLEAREED.AND YOU CAN TRANSMIT THE REMAINING PAGES.YOU NEED ALSO TO TRANSMIT THE PAGE WHICH WAS BEING SCANNED WHEN THE MEMORY FILLED UP.
PRESS STOP IF YOU WANT TO CANCEL THE TRANSMISSION.
SOURCE: UX-B800SE Fax
First it would seem as though the default setting may have all been changed. The NO SERVICE message is given because the machine menu setup is not able to comply with present hardware configuration. Such as the menu setup calling for the incoming fax to be forwarded to an email only you have not connected the machine to an internet router.
The most likely thing to do that will fix the fax not being automatically answered is this.
Check this menu setting. Press the <RESOLUTION RECEPTION MODE> Button (with no document in feeder) until AUTO appears in the display to set auto recieve faxes.
This will auto answer a fax after the set number of rings (different menue option). As someone may have changed this it can be from 2 to 5 rings. Note there is also a pseudo ring tone which can also be set although this will only ring on the machine itself.
This is in case the machine auto answers then finds the incming call is not a fax and so need to altert you to take the call.
Now this is a very complex machine so CAUTION when using in a doctors surgury. It is capable of BROADCASTING all the faxes to any other fax machine or email adresses either by design or the office 'meddler'.
You should set the SECURITY password option and keep a copy of this safe to avoid unauthorised access or changes which could then forward your faxes to unknown destinations.
You need to take a week off to read the manual as it is not easy to plough through.
Here is a link to the MANUAL also what is laughing called a 'setup guide'. My advice is to first disconnect the phone line, then go through each menu setting the DEFAULT value. Then try it, then change the setting to suit you. This is no ordinary fax machine.
http://www.manualsmania.com/model.php?model=6a539582aaef41608ed1fb531d872ebc5098af39
You will of course want to selct the English language GB version of those listed. Then enter the anti-spam code which will download the PDF documents.
Any problem with this such as the link disapearing then i will redo it.
SOURCE: Printer Error Fax RX in Memory
I found that once I had posted my question I was able to get into the on-line manual, once you move all the way though the pages (it won't let you jump to the end and work backwards) the solution was right there.
I had the same "Full Memory" problem & called Sharp. You need to unplug the fax, then hold (press down) on both the "Start/Memory" & the "Stop" buttons at the same time. While holding them down, plug the fax back in. After it's plugged in, you may need to press the start button again. That should clear it.
SOURCE: How to Clear Memory in Sharp Fax UX P115
call sharp tech support (905 568 7140) for instr. they are very helpful and will guide you thro' the deleting memory process in madel ux-p115.
thanks
lk
* Click the "Menu" button.
* Press the arrow buttons to scroll through the options on the screen. Select
"MEMORY REFERENCE" and click "Start/Copy."
* Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
* Click "Stop" to finish.
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
