When i connect head set i can listen to the audio in normal cases but when it is in skype or something like that headset nevr works.. only speakers works
Did you try to check if the same issue occurs with a different headset?
• Do you remember making any software/hardware changes after which the issue started?
I would suggest you to make sure that you have latest compatible and updated drivers installed for the sound device on the computer. Microsoft will perform a free diagnostic scan and fix with three easy clicks. CLICK HERE
SOURCE: Sound Quit Working on Dell Inspiron 5160
log on to support.dell .com
click on drivers and download
put in your service tag and you will get list of drivers
download latest audio driver
uninstall previous driver from device manager
restart the system and then install downloaded drivers
or else provide me the servica tag on your system its at the bottom panel, you just have to put your laptop upside down
i'll send you a link for audio driver compatable with your system
or else if you are in UNITED STATES call 1-800-624-9896 Toll Free
SOURCE: Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
SOURCE: Laptop speakers not working
Hi you can try this:
From Start, go into Control Panel, then select Sounds, Speech & Audio devices, then Sounds and Audio Devices again.
On Volume tab, click on Advanced. Now choose Laptop stereo speakers. This may sort out the problem. Try the other options if they still don't work.
SOURCE: Dell latitude D620, no speaker sound
you will have to uninstall your audio device, and uninstall SKYPE and re install the audio device and don't re install SKYPE, you can do this by going to add or remove programs, and remove SKYPE first and unplug u r headset and mic, and after removing skype you can reboot the computer, and sometimes the conflict is resolved, otherwise then go into your device manager in system manager and find audio devices, unistall the driver or Update the driver, and reinstall it and the reboot, that should take care of the problem.
