The drain hole at the back gets iced up every day and the water spills into the bottom of the fridge. The back of the fridge behind the salad drawer also gets iced up.
Honestly, it really sounds like your problem in the drain is blocked and is overflowing causing a nightmare. I'm assuming it starts just at the bottom of the back wall just around the first set of drawers. There is a kit that they make that actually resolves this issue. Unfortunatly, after looking it up they actually discontinued that part for your model. Not to worry, I'll tell you how to build on. You'll want to remove the drawers and the shelfs and the back wall. For maximun ease I recommend turning the machine off for a day or two and letting everything thaw out. Once the back is off locate the defrost heater. It will run along the bottom of the evaporator. Now, find the drain hole in the trough below the heater area. Once you;ve done that find an aluminum can and good pair of scissors. Cut a strip that can fit down the drain hole, but not to small or too big. Be sure to make it a decent length. Take one end and sort of wrap it around the defrost heater directly above the drain hole then have the rest of the strip go into the drain. How this works is everytime the machine goes into defrost, this ice will melt and the water will fall to the trough where it will go to the drain. The bad thing is hot water actually freezes faster than cold, but with the aluminum improvised drain heater, heat from the element above will pass downward to the aluminum keeping the water warm enough to not freeze as it goes down the drain and finally out of the machine. Your problem will be a thing of the past. Good luck
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Testimonial: "This sounds like it could be the solution - going to defrost the fridge/freezer and give it a try. Thank you !!!!"
SOURCE: Water colecting on floor of freezer in
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
SOURCE: water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
SOURCE: WATER LEAKING IN MY FRIDGE
OK I will try to help but I see the date of your post is close to 2 weeks ago. Sea Breeze
SOURCE: I have a zanussi ZI 920/9K and the fridge has
two solutions
1...a door seal leak
2...you are puting food in that is warm or not covered and its the condensation from these that collects on the shinny surface of the salad drawer.....
remember,every time you open the door warm air from the kitchen replaces the cold air inside the fridge,it does not dry the air like a dehumidifier....
hence water droplets gather.....
Just do not buy a Baumatic so called 'frost' free fridge/freezer as they are rubbish. They ice up everyday. Have to leave mine open everyday to get rid of the ice.
