My television keeps switching itself off, but not fully, so that it is on standby. Sometimes it will switch itself back on again too. The red standby light flickers, its as if someone with a remote control is pressing buttons! The problem started when I moved the TV into a different room, it was not damaged in any way through moving. The television is approx 5 years old and tre problem has got progressively worse, in that every time it is switched on now, it more or less immediatley switches itself back off again. My JVC {AV24WT5EK} TV has suddenly started to switch itself onto standby a few minutes after switching on. Pressing the standby button does not switch it on again. It works ( for a few minutes) when I switch off, then on and then the standby button. The TV originally did not require the standby button to be pressed when it was switched on. The Sleep timer is OFF.
tv was working fine, then all of a sudden the screen goes black. the tv is turning itself on then off again within seconds. iv only had this tv 2 days. its a 42ich lcd hisense. really annoying when you pay that kind of money!
I have the problem
My JVC TV has just started to switch itself on to standby within about 3-5 seconds of switching it on. To switch it on again you have to turn the power off completely and startover again. A day before this it randomly switched off twice but was able to be switched on again, and the screen went a bit funny with a black line down each side.
almost exactly the same problem with my jvc tv.keeps switching itself on and off
