Mitsubishi VS-60719 60" Rear Projection Television Logo
Kevin Vega Posted on Jan 28, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi vs 60719 - Wavy bow in picture
My 60" tv just started experiencing this problem. TV is about 5 yrs old. About 6 inches from the top of the display there is about a 12" bow in the picture. It bows to the left. Any idea what the problem is? Is this something I can repair myself? If this needs to be professionally services, approx cost? This would have to be an at home service since TV is too large to move. Thanks
Bill Heronemus
Level 2:
Sergeant:
  • Expert 308 Answers
  • Posted on Jan 28, 2007
Bill Heronemus
Expert
Level 2:
Sergeant:
Answers
308
Questions
7
Helped
129323
Points
612
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
WE HAVE A MITSUBISHI VS-60719, AND THE PICTURE LOOKS LIKE 3D AND WARPED, DO YOU KNOW WHAT THE PROBLEM IS AND IS IT FIXABLE
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Need anwsers asap! Mitsubishi VS-60719 60 in
Can you psot a picture of what the lines look like and I will try and help you out with it. Please reply to this same post each time. Thanks
2helpful
Picture zooms in then out very fast then stops
try to see if it happens more in bright wight sens if so replace the regulator and check for bad solder connections
Mitsubishi 6071 April 1994 NEED HELP!!!
these sets have bad connections in the picture yokes take the spekerr grill off and front cover move the wires around and see if the pic comes back be careful ok
Mitsubishi VS-60719 60" Turns off
replace the regulator and check for bad connections
Mitsubishi Vs-6071 Picture
replace the signal board (one with all the rca's on it) and not the main board if a plain antenna works OK
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
