Which amplifier plates can replace for Polk Audio PSW-1000 Amp
SOURCE: Polk Audio PSW 350 sub has no power
Hi, Just call the parts line at Polk Audio. They should have the fuse. You can also ask for technical if you're not sure of the problem. Here's the number for Polk: 800-377-7655 Good luck to you.
SOURCE: Optimum set up for Polk Audio PSW 10?
Run 2 RCA cables from the two Purple connections on your Receiver (Labled "PRE OUT SUBWOOFER") to the Red and White connectors on the back of your Sub (it does not matter which Purple connecter you plug into either the Red and White)
Set the volume control on the Sub to about 75%, and keep the power switch in the "ON AUTO" position. To set the Low Pass value, look at the back of one of the front speakers in your setup, and note its frequency range (will look something like 100Hz - 17kHz). Set the Low Pass at a value slightly higher than the low value on the back of your surround speakers.
To set the phase switch, stand in the middle of the room with some music on (something with some bass, but not over the top bass) and have someone switch between 0 Deg and 180 Deg. Listen for which setting sounds "Louder and Fuller". This is the one you want. You will need to do this each time you move the Sub, as its position may change its phase in relation to the rest of your system.
Good Luck!
SOURCE: my polk psw 10 keeps
Unplug the power, get inside it and disconnect either lead to the driver; stand back and plug it in to see if that helps. If so, the woofer is shorted and can be replaced failry cheaply. Otherwise it's probably more complicated and expensive for a hands-on tech to isolate the electrical problem.
SOURCE: I have a Sony Suround sound rec. mdl # STR-DE675
The Left Line in, usually or get an RCA Y-cable adapter and share it between the two inputs.
