Carefully is the main thing.
Most have to be correctly laid face down on a padded surface to remove the cover--any downward force or pressure on the front screen and set can be instantly destroyed.
You want it so when face down entire frame around the screen is supported with NO weight on the actual glass of the screen.
In this position it is usually just removal of screws--a base if mounted also usually has to come off the set to get the back off.
What is issue in set that makes you want to open it, what are you wanting to do?
