It dpends. see if you can see any staining on front of cabinet under the door , if you can then yes it will mean new seal.
Another source of water could be water from the dispenser trickling down the front of the m/c.
Another possibility is that you have a leak from under the front of the washer. Put a piece of newspaper under the front of the washer, this should enable you to pinpoint the source of the leak.
Hope this helps
Please leave feed back
leaking water through the front door
