Question about Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer TSF-49SD
Defrost adjustment how to adjust defrost time
2 Suggested Answers
6ya staff
SOURCE:
Dennis Boxerman
  • 1300 Answers
SOURCE: Defrost times and adjust
http://www.turboairinc.com/TB-Service/Service%20Manual%20%20-%20April%202008/TSF-49SD.pdf
go to this site and check out the service manual. I guessed at the unit you had as you did not include the model number.
You can also go to turboairinc.com and search for more info if you need to.
Hope this gets you your answer.
Posted on Apr 18, 2010
Were is the defrost timer
Delfield freezers have defrost in the control. It is a thermostat, defrost control, and other things all rolled into one device. Not adjustable in any way. check the manual for details. http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/6000XL%20SERIES_spm.pdf
Oct 05, 2014 | Delfield Freezers
The evaporator coil now it frozen , so can you show me how to deprost the ice Thanks
This unit should have a defrost timer on near the compressor. You can turn the dial so it is the area set for defrost time. Usually times are set for 6 am, 12 pm, 6 pm 12 am for around 30 minutes. Adjust the timer dial to where the screw is. Or you can just unplug it.
Aug 14, 2011 | Delfield 113.28 cu. ft. Commercial Freezer...
Whirlpool refrigerator type 2255A The problem I
check your defrost timer manually rotate it possible stock up or replace if damage check the resistance of your defrost heater if good the freezing is normal try to adjust it to the next level of adjustment then conduct observation. check also the thermodisc it is connected to sense the ice vulging of your unit that trigger the defrost heater and defrost timer observe unit.
Feb 19, 2011 | Whirlpool Freezers
Freezer is defrosting
try to adjust thermostat setting together with the defrost timer. check and clean condenser and fan blower if working observe compressor if working continuesly.
Feb 08, 2011 | Samsung Freezers
Turn fridge into freezer
Not really. UCR means under counter refrig. It could freeze some products, like lettuce, but the unit will not function for long periods of time as there is not defrost cycle and it will freeze up.
Jul 22, 2010 | Beverage-Air 6.2 cu. ft. / 176 liter...
I have a Woods model F16CVREC freezer that has formed ice within the freezer compartment and warmed to the point of defrosting the food within the unit. Any ideas what the problem may be? Thanks Islander
This freezer has a thermostat that adjusts the coldness of this fridge marked on different ranges from lower to highest, if digital it's adjusted according to coldness you need your consumables to be. so try to adjust it to colder values or it mayn't be faulty not responding either not switching on compressor, this is why it warms up or switches on the compressor with out switching it off for a long time.
It also has a defrost timer that may need to be checked,even the compressor should be checked to
see weather it's working perfectly,plus the compressor relay this is attacked to the compressor
it could be tripping due a malfunctioning.
Contact a service engineer let him/her visit the mentioned areas.
Hope it works for you.
May 18, 2010 | Freezers
Apr 15, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Need to replace defrost heater in freezer
It could be the defrost time clock. if this is a self contained freezer the timer is kind of oval in shape their is a small hole with flash light should see some thing moving if not it's the timer you can turn adjusting stem until you hear it click that should put in defrost if you have an amp meter you can measure the amp draw should be around 2-3 amps or their is a klixon high temp limit is bad you likely need service. Tom
Jun 17, 2009 | Freezers
Our blast freezer continues to frost up inside leaving icicles hanging down from the fan and a large icicle hanging from the top left white plastic piece. There is a defrost cycle. Should I somehow adjust...
Defrost termination is not working it should be terminating on temp. its terminating on time if it is a small blast freezer their is a high limit switch not opening. if you can adjust the time average defrost time 25-40 minutes try decreasing by 5 minutes no less than 20 minutes you will need to make sure that the coil clears after defrost.
How do you adjust a Westinghouse 2 dooe refrigerator door
Loosen the top hinge screws.
Pull up on the door to where you want it.
While holding the door in place, re-tighten the screws.
Mar 11, 2009 | Frigidaire Freezer Refrigeration White...
Turbo Air 49 cu. ft. / 1388 liter Commercial Freezer TSF-49SD Logo
47 people viewed this question
Top Turbo Air Freezers Experts
Dennis Boxerman
Felizardo Erilla
Felizardo Erilla
Todd B
Are you a Turbo Air Freezer Expert? Answer questions, earn points and help others
