Question about Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
How to hook up a internal hard drive as an external hard drive
I need a diagram showing how to splice a WD3200AAJS into a usb cord
    Top Expert:
  • 4,961 Answers
You can't spice a sata cable into a usb cable. You buy an external enclosure like this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817173042
Posted on Jun 15, 2012
6ya staff
SOURCE:
videoclinic
SOURCE: External hard drive not recognized
I recenctly bought a my book 500 gig drive and it is usb.
the firsttime I plugged the usb cable in it worksed. I had only a 40 gig ide harddrive and so I ordered an internal 500 wd hard drive to replace it. The internal 500 gig is a sata drive. first I cloned the 40 to the sata 500 and then copied the external 500 to the internal. I mover the cables to then make the internal 500 sata my boot drive. The computer would no longer show the external e\when i used the windows explorer. the device manager said it was there and working with no problem but windows did not see it.
After several experiments with diferent configurations I have concluded my motherboard wasauto configuring the external and internal 500 drives as drive 0. Since the usb was detected first and was notthe boot drive then windows assigned the internal drive as drive 0 and since the usb drive was drive 0 also it would not work. windows ignored it. my solution was to return the ide as the boot drive and plug the sata into a slave port. with that configuration both drive are seen and work normally. It took me several days to find this arrangement. so since my sata ports are auto configure and the external has a sata connection i will install an esata port adapter and try to hook it up as a slave sata drive so i cab\n use my internal 500 sata drive as my boot drive.
sorry this was so long but it is my solution to what others may be facing.
Posted on Jun 08, 2008
Anonymous
  • 17 Answers
Try these steps: - Right-click on "My Computer" - Click "Manage" - Click on the "Disk Management" icon in the left column (Under the "Storage" category" - If your disk appears on the right-hand side, then try to right-click on it and create a partition. The issue may just be that, since the disk is not partitioned/formatted, a drive letter has not been assigned, which would cause it to not show up in the "My Computer" list Good luck!
Posted on Oct 07, 2007
Anonymous
SOURCE: My Computer does not show: Western Digital My Book Essential Edition 500 GB external USB hard drive
Well i got a simple 320 gb external hard drive, and since the first month i had problems, i solve the recovery issue by opening the hard drive, and find it out, the inside was broken, and it got unplugged. so plugged it back and got my info. if your data its more important than 200dlls or less break the thing open, because if you claim the warranty they are not responsible for your information.
Posted on Dec 13, 2008
Anonymous
  • 40 Answers
SOURCE: External Hard Drive Not Regonized
I can help you with this. Follow these instructions--> Start-->Control Panel-->Administrative Tools-->Computer Management, under the Storage section select "Disk management". Locate the external harddrive, and then change the drive letter.
Select the external drive. Right click, and select "Change drive letters and paths"-->Highlight the driveletter to change-->Click the "Change" button-->From the drop-down list choose an unused drive letter, and hit Ok.
The external drive should be recognized and accessible at this point. Let me know if you have any other questions.
Thank You, Raph30
Posted on Jan 28, 2009
Anonymous
  • 1179 Answers
SOURCE: WD Caviar SE16 WD3200AAKS 320GB 7200 not recognized at install
Windows XP does not have built in SATA drivers. You will need to download the XP drivers from Western Digital's website and install before the computer will allow you to format and use your new drive. Hope this helps.
Posted on Jul 19, 2009
My computer doesn't recognize my hooked in to 3.0 USB port on my ASUS laptop, initialized, SATA 2TG internal drive that's within an external case.
depends on the operating system but normally if you can see the drive in pc manager (right click mycomputer icon, select manage, select disk management in windows) if the drive is listed then format it and allow automatic drive letter assingment
Mar 20, 2014 | Western Digital WD Caviar Blue WD3200AAJS...
When hooking up my 120 Gb external hard drive to my laptop, I noticed there was an additional power supply required, DC by the look of it. I can't seem to find the correct size of outlet, or even an...
hi
The SimpleTech SimpleDrive Portable external hard drive features a USB 2.0 interface for speed and plug-and-play connectivity. The hard drive is USB -powered, so no extra power supply is needed.
please send me 4 thumbs up
Jul 16, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
My external is hooked up to the frame through the usb, but itwill only let me choose internal memory or slideshow folders, it wont let me choose usb when i try to select media sources. how do i get it to...
The external hard drive is diferent from a regular USB stick, so this is probably the case. You could check the manual of the photo frame and the manual of the externa drive, probably you will find some settings that reffer to this.
You could also check that the external drive is plugged in to AC, and turned on, many drives require alternative power source when conected to low power readers like your photo frame.
Apr 07, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
My external hard drive had the click of death. I
YOU HAVE TO PUT IDE OR SATA CABLE TO THE DRIVE AND ONE MORE THING IS 4 PIN SUPPLY FROM SMPS.YOU HAVE TO PUT CONNECTIONS LIKE THE FIRST HARD DRIVE ALREADY IN THE COMPUTER
Apr 04, 2010 | Computers & Internet
I have a WD 500GB External Hard Drive. It has
That could even be a USB problem, I have the same one, my issue turn out to be just power. You are not the first one to have that problem. Replace the USB cord and see if that affects anything.
Mar 25, 2010 | Western Digital My Book Essential 500GB...
Hard drive connects and then disconnects quickly
Sounds like a bad solder joint or break on the circuit board. If the data on it is important, you may need to use a data retrieval service.
Jan 18, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Hooking up a
Your external drive has a choice of USB or firewire, so only connect with the USB cable.
Dec 05, 2007 | Western Digital External USB 2.0 80 GB...
Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA Logo
588 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
ChinthakaJ
ChinthakaJ
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
