SOURCE: How to install java application and games on J600
For installing games stored on youre phone ( .Jad ) try the java midlet install menu: code *#9998*5282# -> install MIDlet password: 235282
Then you can select a .Jad file (.Jar must be included) stored on youre phone Memory (Stored on MicroSD probable too, but i don`t have one yet)
after install apps/Games, they are in the: application -> Java world -> "My Games" folder (menu-3-4-My Games)
I have the E900XXFF2 Firmware, the password works fine on it. I think on other versions too, because the password was meant for Samsung D807.
enjoy the pass, if it works on youre firmware, but i think it will work :)
*#3243948# Digital Audio Interference Off
*#32436837# Digital Audio Interference On
*#1111# Software Version
*#2222# Hardware Version
*#1234# Firmware Version
*#92782# WAP User Agent
*#927827# WAP WAProfile
*#0228#/*#9998*228# Battery profile
* # 0842 # Vib test
* # 0746 # SSMS MEMORY
* # 0638 # SIM SIM network ID
* # 0778 # SST Sim service Table
* # 0289 # Buz test
* # 0782 # RTC (RealTimeClock) (# = Refresh)
* # 9998*228 # Battery Profile
* # 9998*842 # Vib test
* # 9998*746 # SSMS MEMORY
* # 9998*638 # SIM SIM network ID
* # 9998*778 # SST Sim service Table
* # 9998*289 # Buz test
* # 9998*782 # RTC (RealTimeClock) (# = Refresh)
* # 9998*968 # YAMAHA OF OK ONE
* # 9998*76 # Product NUMBER
* # 9998*377 # error memory
* # 9998*5646 # GPRS Logo
Code, whose effect and/or function I exactly do not point
* # 9324 # monitor? (with the red key velassen)
* # 32436837 # DAI ON?
* # 22766 # Automatically Recive call?
* # 227633 # manual Recive call?
!!! RESET code!!!
!!! these codes use only if you know which it does!!!
!!! Thus data in the Handy are deleted!!!
* 2767*3855 # FULL RESET
* 2767*2878 # CUST RESET
* 2767*927 # WAP RESET
* 2767*667 # MMS RESET
* 2767*36245 # email RESET
SOURCE: install java on mobile
I have SGH-J210
It seems that you can only download games from internet. As soon as you click on java app/game file link in the browser. The Java install options appears and the app/game is installed.
I tried all ways to install games from PC to cellphone. But so far I am unsuccessful.
plz i want to u600 install appilcation bible dictionary
SOURCE: installing java games to SAMSUNG E250
I finally succeeded in installing some java games to my Samsung E250 via bluetooth. I thought I would share the info on how I do it here because it seems to be a frequent unanswered question on various forums. You will need a *.jad and a *.jar file for your game. 1) Download Softick PPP and Samsung Java Uploader.exe . Also JADmaker if required. 2) Install SoftickPPP according to this Polish website. I don't understand Polish, but the pictures tell enough of the story. Set up your bluetooth COM ports in the SoftickPPP bluetooth/serial settings. My Bluetooth COM ports are either 24, 25 or 26. I leave them all ticked. 3) Enter *#52828378# on the phone to access the Java Test Menu. Choose OTA type setting, choose Serial bearer OTA. Click select. (This seems to need to be changed back to GPRS bearer OTA for Samsung PC Studio to connect) 4) Start SoftickPPP. Click on cancel for the missing USBPort.dll error message. Accept bluetooth connections for DUN and Serial connections on the phone. 5) Choose 'Activate PPP' by right clicking on the icon in the taskbar. Accept connections on phone again. 6) Start 'Uploader.exe' and then add the required jad file. Leave the program open. 7) If you are not still in the Java Test Menu then enter *#52828378# on the phone again. Select 'Serial test', 'PPP Up', 'Bluetooth' on phone, 'Serial download'. My phone sometimes restarts at this point in which case I have to choose 'Shutdown PPP" in the taskbar icon and then re-activating it once the phone has restarted and then re-do step 7 after entering the Java Test Menu again. A Java splash screen should appear with a progress bar showing the upload of the file. The game then starts automatically. There we go. It works for me Please man do you speak bosnian..
.Quote:
1) Type in the code *#9998*52824678255# (which reads *#9998*JAVAINSTALL# )
2) Your phone should return with 'Activated'
3) Now using Bluetooth or USB cable, connect to your phone (IR probably works too)
4) If you have a game as .jar, but don't have a .jad file, use JadMaker to create one (draw the .jar file to it and it will generate a .jad file for you).
5) Copy the .jar AND .jad file of the game into the map called "Other Documents" on your phone.
6) Now on your phone under 'My Files' browse to the 'Other Documents' map and doubleclick on the just copied .jad file.
7) The phone will ask you if you want to Install the game.
8) After Install you will find the game under Games on your phone.
9) You can now remove the just copied .jar and .jad file again (they were only there to install the game onto your phone).second answer:that i go to samsung company and when i ask them about jave install on samsung they say to me that the only way is to download from mobile internet games but it will be triall expet a game called 4*4 extreme race only and i tried to install any game it will be trial thanks for your reading (trusted)
SOURCE: Samsung E200 java installation "install error"
you can install using java uploader but it's a quite hard procedure.
better yet, try to upload using your wap. it'll cost you internet
browsing but it's worth it. there are a lot of wapsites that give free
jad games.
by the way, .jad files fit samsung phones the best.
