Has dvd also
SOURCE: universal remote codes
here are some codes that might work 0456-0004-0009-0044-0135-0049 the first one might be it if you don't know how to set it here's how press setup and hold it until the light stays on then press t.v. and then the code. hope this helps
SOURCE: yes i have a emerson tv but have a universal tv
try these codes.0177,0087,0714,0247.1909,0486,0370,0163,0361,0178
0178,0037,0556. Hoping ones thses work if not contact remote mfs as some sets require update
SOURCE: need code number for emerson TV to set up on sony remote
Go to http://tvservicemenu.blogspot.com for more help.
SOURCE: cant see dvds on my emerson tv
Hello.
In many cases by connecting the DVD via a scart cable (depending in what country you live in if your system supports it)
the dvd will send a signal to the TV to switch over to RGB mode when you start playing the dvd. Rember to make sure the scart connectors are firmly pressed into their sockets on both tv and dvd.
Also if you found out how to switch channels directly on the TV try to go through them ...you might find the AV channel that will show the picture from your dvd.
Hope this will help you.
Good Luck.
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
