Vizio L37 Television Logo
Posted on Dec 01, 2008
Playing vcr causes new digital tv to lose saved channels
Vizio VO37L tv loses the same two channels each time we play the VCR. They can be regained by unplugging the TV and plugging in. That resets the channels. The antenna goes through the VCR (no cable service) could the connection be modified to prevent the problem?
thibsrus
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 02, 2008
thibsrus
Contributor
Level 1:
Answers
Questions
Helped
307
Points
Vizio representative suggested connecting antenna directly to TV and not through the VCR. In doing this, we lose the ability to record on the VCR but we record elsewhere and watch downstairs. The problem is solved on losing channels. I must add that we watch and record on a Sharp digital TV upstairs and do not lose channels. I don't know why the VCR had this effect on this Vizio TV.
1helpful
I replaced my TV and now my VCR Zenith Model 2100 will not record
Digital TV can use component video and stereo connections to record on analog VCR. Analog VCR needs DTV converter to record digital TV channels. VCR play back use AV channel on TV.
I cannot get the Vcr/ Dvd to play
The TV needs to be on channel 3 not channel 3.1 because is a digital channel and the signal from the VCR is analog. Tune the TV to channel 3 to get the analog video from the VCR.
1helpful
Unable to operate recorder at all.
When you are turning the recorder on it is blocking the signal for cable going to the TV. Your TV will need to be on channel 3 or 4 depending on what the dvd/vcr player channel output is set to. This is why your tv is asking you to re-scan. It is losing the video signal because the dvd/vcr is taking over. The reason why the vcr with the button on the remote is because the vcr button is changing the function of the buttons on the remote to vcr. Even though the dvd/vcr is one unit they still will act like two seperate components independent of each other. They have seperate power buttons and the dvd player part may need to be hooked up seperately with rca cables to work.
Trying to help this older lady with a emerson tv/vcr combo. She has no manual with set. Setting up to record same station everyday at same time. VCR will record but when playing back she only gets sound no...
The TV should be on channel 2, 3, or 4 to work correctly. There might be a small switch on the back of the VCR that lets you select the channel that it wil play back on.
Also, look on the remote control for the VCR and see if there is a button labeled TV/Video, and press that while something is playing. This switches back and forth between the TV signal and the VCR signal and it could solve your problem.
1helpful
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
New hdtv
First off, scart has an auto detect feature across pin 8, HDMI does not. If you have turn your TV to the HDMI channel, and at some point turn off the HD source device you are going to get a blank screen, you have to manually turn your TV back.
In regard to whilst you are recording it sounds like you may have tuned in channels on your DVD but not your TV.
Do you have an RF aerial lead connected from the DVD output to the RF on you telly?
Do you have a sky/cable box connected to your TV via scart?
Does the DVD have DVB (digital video broadcast) if so and you have none of the above that is the problem, any tuner running off a single RF lead can only record/play 1 channel at a time. If you have no RF lead going to the TV, then the TV cannot show any terrestrial channels.
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
2answers
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
2answers
Loss oF color
Bad chroma processor...accordianman
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
