2000 Chevrolet Blazer Logo
A
Anonymous Posted on Feb 23, 2018
2000 BLAZER LOW FUEL PRESSURE
AT IDLE, FUEL PRESSURE IS 52PSI. VEHICLE HAS INTERMITTENT MISS. RUNS LIKE YOU'RE TOWING A TRAILER ALL THE TIME. VERY SLUGGISH, FUEL PUMP WAS REPLACED A YEAR AGO, WHICH DIDNT SEEM TO MAKE IT RUN ANY BETTER, O2'S,FUEL FILTER, MASS AIR, EXHAUST SYSTEM INCL CAT-HAS ALL BEEN CHANGED.
3 Related Answers
Anonymous
  • 3917 Answers
  • Posted on Jul 26, 2009
SOURCE: I have a 97 blazer
It was something that takes a lot of time and money to diagnose.Emissions requires the truck to have an EGR valve (exhaust gas recycle) and this deposits gunk (carbon residue) on your MAF (mass air flow sensor) If you catch it in time you can use a carbon cleaner from Autozone or checker Lightly on the MassAirFlow sensor. If not in time you may have to have either the MAF or EGR valve replaced and these are expensive. After a long period of time being undetected eventually the EGR valve will start smelling like sulfer, this means its to late to clean and save.
Thanks for contacting Fixya.
Anonymous
  • 636 Answers
  • Posted on Aug 15, 2009
SOURCE: No start. Ran sluggish for a few miles. Fuel
I would lean towards the pick up pump not delivering the fuel .
Hope this helps.
raj somaiya
  • 5370 Answers
  • Posted on Jul 12, 2011
SOURCE: I HAVE A 2000 S
Check the PCV system .You can pull the oil cap or the oil dipstick with the engine running to see if there is engine vacuum in the crankcase.
Pull the dipstick and put your finger on the hole and if you feel a vacum then it's the pcv problem.But if you dont feel vacuum, then its not pcv problem.-----------
As you mentioned that MAF is replaced.Bud did you check the MAF sensor wires with meter.There are 3 wires. one is power wire, that is 12 volt wire.--------
one is ground wire and one is signal wire.The signal wire of maf is controlled by ecm( ecm means cars computer module).--------- If the maf is not getting power it will not work, still its new.------- Same for ground and signal options too.There should be proper signal from ecm.------- Click this link below to go through maf testing:--- http://whatisbyme.blogspot.com/2011/07/maf-testing-on-chevy-blazer.html ---------- This will help.Thanks.Helpmech./
1helpful
96 4x4 Blazer runs rough when you first start going ,when you give it the gas it's having a hard time ,but smooths out ?only low RPM
Very common problem the fuel pressure regulator under the plenum is leaking and causes a rich running condition on start ups and if bad enough can cause it at idle all the time
Miss in 1999 silverado 2500 6 liter
It sounds like you may have a small block in your fuel system. When was the last time you changed your fuel filter out?
2answers
2000 blazer will start and idle fine. but wont take fuel. the rpm will run up to 2000 after 2000 it looses power.i have checked the igntion/fuel presure/replaced throttle postioning sensor/replaeced fuel...
CHECK THE JETS , YOU HAVE GAS PRESSER BUT YOU COULD HAVE MAYBE JET PROBLEMS AND CHECK AIR HOSE'S.
GAS-------INTO-------JETS---into---------ENGINE-----LOW RPM
2helpful
2answers
Low oil pressure after engine warms up in 94 blazer with 4.3
I have a 99 blazer and ever since I have owned it, it reads lower in pressure when idling, but will go up too 40 while driving. This is normal for the vehicle. If the pressure gets real low, and stays low, it means its time for an oil change.
As long as the pressure goes up when you give it gas, it is fine.
2000 Chevy s10 2.2L very rough idle at low rpm
run a fuel pressure test, if that checks out fine it may be a faulty coil pack or ignition control module
Towing light problem on wiring them up.
It looks like there could be a service bulletin to fix this.
TO: ALL TOYOTA DEALER PRINCIPALS,
SERVICE MANAGERS, PARTS MANAGERS
SUBJECT: SPECIAL SERVICE CAMPAIGN 10H
(2000 TUNDRA AND 1999 - 2000 TACOMA TRAILER TOWING WIRE HARNESS
CONVERTER REPLACEMENT)
Toyota will initiate a Special Service Campaign to replace the Toyota Trailer Towing Wire Harness
Converter (converter) on certain 2000 model year Tundra and 1999 - 2000 model year Tacoma
vehicles equipped with a genuine Toyota Trailer Towing Hitch or Bumper Hitch. This accessory
is included in the Towing Hitch Kit installed at ports (PIO) and by dealers (***); it is also sold by
dealers as an over-the-counter or service part.
An electrical short or open circuit can cause a fault in the genuine Toyota Trailer Towing Wire Harness
Converter (converter). This can cause a failure of the converter, and if a trailer is being towed at the time,
non-operation of the trailer lights. In limited cases, the converter housing could become heat-deformed.
In the case of the Tundra, the circuitry utilized in the converter was inadequate to properly manage
vehicle and/or trailer-side voltage spikes. If the converter is exposed to a voltage spike it may cause an
electrical short or open circuit within the converter.
As for the Tacoma, due to deficient waterproofing and improper installation location of the converter,
which is mounted in the lower portion of the taillight cavity of the vehicle, an electrical short circuit will
occur if water enters the converter housing.
The following vital information is provided to inform you and your staff of the campaign notification
schedule and your degree of involvement.
1. Owner Notification Letter Mailing Date
The owner notification will be conducted in two phases:
• The first phase will be launched in late August and involve vehicles equipped with port
installed (PIO) genuine Toyota Towing Hitch Kits.
• The remaining vehicle owners, whose vehicles may be equipped with a dealer installed (***)
genuine Toyota Trailer Towing Wire Harness Converter, will be notified in the second phase
to be launched in early September.
We have attached copies of the owner notification letters for your reference.
If you are contacted by an owner of an involved vehicle, who has not yet received a notification,
please verify eligibility through TDN or TIS, inspect the vehicle to assure it is equipped with the
affected part, and perform repairs as outlined in the attached Technical Instructions.
2000 Chevy blazer this is the 2nd brand new fuel pump I've replaced in 2 weeks,It runs a hour or two, Then sitting all night won't work in the morning.Same thing the first time . I've checked fuse ,...
Spark......EQUIPMENT NEEDED: 1) fuel pressure Gage....Advanced Auto = $45..... 2) needle nose pliers ( fuse pull )..
There is a fuel pressure access valve located on the fuel injector rail. The access port or "shraider" valve has a black or gray screw on cap. Remove the cap and you will see the valve. CAUTION: The fuel rail is under pressure....before installing the pressure gauge, relieve pressure by starting the engine and removing the fuel pump fuse from the under hood fuse box......
Once the engine quits, turn the key to the off position and safely install the pressure gauge. Put a rag around or under the access valve to catch any drizzling fuel. I always prefer to do this when the engine is cool.
Install the pressure gauge, start the engine, check for leaks and read pressure output at idle, record pressure reading.
Also, it should be checked under load but you will need another person to help.
Once you have shut the vehicle off watch the pressure gauge, it should remain steady and not leak down.
Let me know what the readings are.
Regards,
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
