Put in neutral, not running to push it into the garage, couldn't push it, rear wheels just slid
It sounds like the tractor is hydro, if so you need to find the release lever to allow it to move in neutral.
Most hydros have the lever under the seat or at the back of the tractor just behind the back wheels.
if and when you find it, it will need to be slid across and locked in to the operset position or pulled out, depending on what type it is.
Hope this helps
Regards
Micky
SOURCE: reset oil chang warning light
The oil minder light will blink for 2 hrs and then reset itself, i believe it starts at 49 and ends at 51 and then every 50 hrs it will do the same.
SOURCE: how to adjust valves on briggs and stratton 17.5
Remove spark plug
Remove cover from engine that covers the flywheel
Remove rockerarm cover or valve cover
Find TDC (top dead center) by rotating the flywheel by hand and your finger over the spark plug hole as you rotate the flywheel you will feel pressure against you finger at some point then stop.
This is the compression stroke it is called now find a long slim round piece of plastic or plastic ink pen to stick in the spark plug hole (If you are careful a slim screwdriver can be used ) and find the piston top, then slowly rotate flywheel again (cw) as the piston is moving up pushing the plastic up as you rotate the flywheel slowly.
a max. piston up or tdc as you turn you will feel and then the piston starts to go the other way,at that transition this is tdc (piston is on top of stroke) leave it there,,both valves should be closed at that point.
Have a feeler gauge and set the exhaust valve at a loose .002 and the intake a loose .004 be sure engine is cold when valves are adjusted
Feeler gauge goes in between the rocker arm tip and valve stem top for each valve setting.
Note the rocker adjustment at the push rod side of each valve by tightening and loosening to make adjustments,lock your adjustments in place and rotate flywheel a few times and recheck settings
SOURCE: Troy bilt lawn tractor that will not go in forward-just grinds
sounds like the trnns has some thing lose in it you will need to get to the shop
SOURCE: need a owners manual for troy bilt 17.5 hp 42 inch
HOW TO CHANGE A BELT ON
SOURCE: Bolens Q683H 8 speed lawn tractor will not go into neutral.
is the neutral safety switch located underneath the riders seat on this machine being depressed fully to make connection or could this switch be bad,if its bad the unit will not start,because the seat,transmission switch,and start circuit are in series and one that isn't closed(as in a switch) will not pass current to the start circuit
